Ana içeriğe geç
Gateway 600YG2 Keyboard Replacement
Elizabeth Mazer
Elizabeth Mazer ve 8 diğer katkıda bulunanlar
En son January 10, 2025 tarihinde güncellendi
15 - 30 dakika
Orta
İşlem Görüntüleri
The Gateway 600 YG2 includes a full-sized 86-key keyboard. Each key performs a specific function when pressed individually or in combination with other keys.
Follow the steps in this guide to replace your keyboard if necessary.
New or pre-owned keyboards can be purchased on eBay. An original factor laptop full complete keyboard with a 2-year protection plan can be purchased for $14.99.
Source: Keyboard Area - Gateway 600Y G2 User Manual
Neye ihtiyacın var
Aletler
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Gateway 600YG2 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the battery cover using the tab on the right side.
    • Use your index finger to help lift and remove the battery.
  3. Gateway 600YG2 Keyboard Replacement, Power Button Panel: adım 3, 1 resimden 1.
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 Keyboard Replacement, Keyboard: adım 4, 1 resimden 1.
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 Keyboard Replacement: adım 5, 2 resimden 1. Gateway 600YG2 Keyboard Replacement: adım 5, 2 resimden 2.
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
Sonuç
Elizabeth Mazer
78 İtibar
10 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 üyesi
CPSU-MANESS-F10S20G10
3 Üyeler
22 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,464
