Ana içeriğe geç
Gateway NV59C66u Battery Replacement
Jackson Gandee
Jackson Gandee ve 2 diğer katkıda bulunanlar
En son September 27, 2020 tarihinde güncellendi
2 dakika
Kolay
Does your computer die sooner than it did when you bought it? You may need to replace your battery as it might be damaged. This step-by-step guide will show you how to quickly and safely replace your battery for your Gateway NV59C66u laptop.
  1. Gateway NV59C66u Battery Replacement, Battery: adım 1, 1 resimden 1.
    • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
    • Locate the Latches below the battery.
  2. Gateway NV59C66u Battery Replacement: adım 2, 1 resimden 1.
    • Slide the vertical latch upward, unlocking the battery
  3. Gateway NV59C66u Battery Replacement: adım 3, 1 resimden 1.
    • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
  4. Gateway NV59C66u Battery Replacement: adım 4, 1 resimden 1.
    • Now the battery is free. Proceed to lift and remove the battery.
    • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
    • Take your new battery and position it into the battery slot you took the old one out of.
    • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
    • Put latches in lock position and turn laptop over.
    • Turn on your computer.
Sonuç
Jackson Gandee
521 İtibar
4 adet Kılavuz yazıldı
Ekip
ETECH Holdings ETECH Holdings üyesi
Community
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 236
