Ana içeriğe geç
Gateway NV59C66u RAM Replacement
Jackson Gandee
Jackson Gandee ve 3 diğer katkıda bulunanlar
En son September 29, 2020 tarihinde güncellendi
20 dakika
Orta
If your computer has slowed down, RAM can be replaced or upgraded to increase performance. This guide will help you to replace the RAM in the Gateway NV59C66u laptop.
Neye ihtiyacın var
Aletler
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Gateway NV59C66u RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Remove the four Phillips #0 screws from the back cover.
  2. Gateway NV59C66u RAM Replacement: adım 2, 1 resimden 1.
    • Gently remove the cover with a plastic opening tool to gain access to the RAM.
  3. Gateway NV59C66u RAM Replacement: adım 3, 2 resimden 1. Gateway NV59C66u RAM Replacement: adım 3, 2 resimden 2.
    • Free the RAM by unlatching the holders. The two arms on either side of the RAM card should be pried away from one another.
    • The RAM will then pop up to rest at an angle to the laptop.
  4. Gateway NV59C66u RAM Replacement: adım 4, 1 resimden 1.
    • Slide the RAM out from the port.
    • Follow the previous steps in reverse to replace the RAM card.
Sonuç
Jackson Gandee
521 İtibar
4 adet Kılavuz yazıldı
Ekip
ETECH Holdings ETECH Holdings üyesi
Community
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 206
