Ana içeriğe geç
Glass Door Latch Replacement
CJ Cummings
CJ Cummings ve 3 diğer katkıda bulunanlar
En son December 30, 2020 tarihinde güncellendi
5 - 25 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
Model: Mortise Latch (Adjustable) Vertical Lever Slot
Model Code: E2013
This fast fix is replacing an adjustable mortise latch to a sliding glass patio door. The goal is to replace the broken/damaged latch with the same model due to the possible home security risk that a broken latch poses to a home.
Note that the latch or its replacement can be lost inside the door if the fast fix is done incorrectly. If you’re unsure that you can keep the latch from being lost, ask a friend or family member for a second pair of hands.
Possible symptoms of a damaged/broken latch:
  • Considerably loose
  • Door can be forcibly opened while locked
  • Cannot be unlocked/locked
Additional Resources: PLPCI Website
  1. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 1. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 2. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 3.
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 1. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 2. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 3.
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: adım 3, 2 resimden 1. Glass Door Latch Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: adım 4, 2 resimden 1. Glass Door Latch Replacement, Mechanism Removal: adım 4, 2 resimden 2.
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: adım 5, 2 resimden 1. Glass Door Latch Replacement, Replacement Prep: adım 5, 2 resimden 2.
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 1. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 2. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 3.
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 1. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 2. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 3.
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: adım 8, 2 resimden 1. Glass Door Latch Replacement, Latch Correction: adım 8, 2 resimden 2.
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 1. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 2. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 3.
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
Sonuç
Bir başkası bu kılavuzu tamamladı.
CJ Cummings
193 İtibar
1 Kılavuz yazıldı
3Kılavuz Yorumları
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - Yanıt
what brand or manufacturer is this door/lock assembly. im trying to find keyed trim for this
yaakov danzig - Yanıt
Thank you so much for this post. I was a little nervous about replacing my sliding door lock. Your step by step instructions with pictures made the replacement of my lock so easy.
Dawn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 25
Son 30 gün: 72
Her zaman: 7,726
