Ana içeriğe geç
GoPro Hero LCD Screen Replacement
Neye ihtiyacın var
  1. GoPro Hero LCD Screen Replacement, Casing: adım 1, 1 resimden 1.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: adım 2, 1 resimden 1.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 1. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - Yanıt
  8. GoPro Hero LCD Screen Replacement: adım 8, 1 resimden 1.
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 1. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 2.
    • Separate the LCD screen from the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
River Drake
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
18 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do you buy the replacement lcd
Anthony Volatile - Yanıt
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING -
I can find the screen but is it compatible with the Hero+
Brian Casado - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 34
Son 30 gün: 156
Her zaman: 25,126
