Ana içeriğe geç
GoPro Hero LCD Screen Replacement
River Drake
River Drake ve 4 diğer katkıda bulunanlar
En son May 26, 2021 tarihinde güncellendi
15 - 20 dakika
Orta
İşlem Görüntüleri
If for some reason, your screen is dysfunctional, you can replace it. Since it is near the bottom of the camera, it is not easy to replace. Grab your screwdrivers and tweezers and let's go!
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. GoPro Hero LCD Screen Replacement, Casing: adım 1, 1 resimden 1.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero LCD Screen Replacement: adım 2, 1 resimden 1.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero LCD Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero LCD Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero LCD Screen Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 1. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    gostaria de compra essa parte completa
    nishiura447 - Yanıt
  8. GoPro Hero LCD Screen Replacement: adım 8, 1 resimden 1.
    • Separate the motherboard from the white piece of plastic.
  9. GoPro Hero LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
  10. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 1. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 2.
    • Separate the LCD screen from the motherboard.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
River Drake
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
18 adet Kılavuz yazıldı
3 Yorum
Where do you buy the replacement lcd
Anthony Volatile - Yanıt
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING -
I can find the screen but is it compatible with the Hero+
Brian Casado - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 39
Son 30 gün: 146
Her zaman: 25,056
