Giriş
This repair guide was authored by a member of the iFixit community and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the fingerprint sensor on your Google Pixel 2.
Neye ihtiyacın var
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Peel back the small piece of tape covering the screw below the earpiece speaker. Peel back any tape covering other screws as well.
Remove the following screws securing the midframe:
Eleven 3.7 mm Phillips screws
One 4 mm T5 Torx screw
Use the flat end of a spudger to disconnect the battery connector.
Use the flat end of a spudger to disconnect the charging assembly connector.
Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
Hold the charging assembly cable out of the way and insert an opening pick along the bottom edge of the battery.
Apply steady, even pressure to slowly lever the battery up and out of the phone.
Only pry from the center of the battery to avoid damaging the delicate ribbon cables beneath either side of the battery.
If you are having trouble, apply some more alcohol under the battery and try again.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Remove the battery.
Use a spudger to scrape away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
Press the battery firmly into place for 20-30 seconds.
use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
Flip the device over so that the display side is facing the ground.
Use your hand to push the fingerprint sensor down toward the inside of the phone.
4 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Replacing the fingerprint sensor. I’m a Medical Device Electronics Technician. Specifically electronic repairs. Everything I repair is designed to be repaired and I have the facilities at hand, to make professional repairs that are FDA certified processes. I’ve tried replacing displays, batteries, and now a fingerprint detector. Thing about most phones is they require heat to both open and re-seal. Think Ametek Hermetic Board sealers. Douglas sandwich sealers. My Pixel 2 finger print sensor got scratched and stopped working. For my Pixel I was unsucessful in reinstalling the display. I got it all back together and working . After 2 weeks the device stopped working reliably. The display peeled off and I was unable to get it to recognize touch. VERY sensitive repairs. It’s why they are assembled in Class 100 clean rooms. A piece of lint is all it takes to short a pixel.
Incredible they charge what they do for a device that cannot be repaired. The phone itself is a inegrated circuit. Insane.
