Ana içeriğe geç
Google Pixel 4a 5G Battery Replacement
Neye ihtiyacın var
  1. Google Pixel 4a 5G Battery Replacement, Eject the SIM card tray: adım 1, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Eject the SIM card tray: adım 1, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Eject the SIM card tray: adım 1, 3 resimden 3.
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM tray hole.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Google Pixel 4a 5G Battery Replacement, Precautionary Notes: adım 2, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Precautionary Notes: adım 2, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Precautionary Notes: adım 2, 3 resimden 3.
    • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of your phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you have to pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin, note the following areas on the screen:
    • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
    i don't understand the "screen flex cable" nor the "adhesive perimeter" instructions
    Jonas Baumann - Yanıt
  3. Google Pixel 4a 5G Battery Replacement, Heat the right edge of the screen: adım 3, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Google Pixel 4a 5G Battery Replacement, Insert an opening pick: adım 4, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Insert an opening pick: adım 4, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force.
    • Insert the tip of an opening pick into the screen seam no more than 1 mm.
    When "lifting" the suction cup, press down while pivoting the handle away from the front/edge, as if opening a door.
    Soon-Hee - Yanıt
    For a very cracked screen, I placed clear packing tape on top of the screen to use the suction cup at all. Also had to suction cup and pry/pick at multiple sides of the screen. Small fragments of broken glass won't pry up, so had to use tweezers to pull at glass fragments to release them from the adhesive underneath.
    Soon-Hee - Yanıt
  5. Google Pixel 4a 5G Battery Replacement, Guide the opening pick under the OLED panel: adım 5, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Guide the opening pick under the OLED panel: adım 5, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Guide the opening pick under the OLED panel: adım 5, 3 resimden 3.
    • This step shows how to insert your pick without damaging the OLED panel. Do this before slicing the adhesive.
    • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
    • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
    You don't exactly have to be utterly careful about damaging the panel. The glass+OLED screen as a whole is being replaced here. So it doesn't really matter if you accidentally damage the old OLED panel.
    Soon-Hee - Yanıt
    If only the battery needs to be replaced, be sure to pay attention to the angle at which the pick is moved. Even the slightest deviation and the display is crap. I followed the instructions, but obviously I got to the display somewhere. Unfortunately the display now remains black and I have a flashing green bar at the top. So be careful.
    RiKER “MANiAC -NI-” - Yanıt
  6. Google Pixel 4a 5G Battery Replacement, Slice through the display adhesive: adım 6, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Slice through the display adhesive: adım 6, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Slice through the display adhesive: adım 6, 3 resimden 3.
    • Slide the pick along the right edge of the screen to cut the adhesive.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
    • Leave the pick in the bottom-right corner to prevent the adhesive from re-sealing.
  7. Google Pixel 4a 5G Battery Replacement: adım 7, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 7, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 7, 3 resimden 3.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • The screen adhesive is weak, so you should not need to re-apply heat. If the screen is hard to slice, apply heat to the difficult area for one minute and try again.
    • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the opening pick around the top of the phone to cut the adhesive.
    • Leave the pick inserted along the top edge to prevent the adhesive from resealing.
    The replacement screen I purchased from iFixit Oceania in Sept 2022 included a new speaker mesh, already attached to the screen.
    Chris - Yanıt
    The corners seems particularly tricky with the adhesive. Make sure to reapply heat in the corners. I cracked my screen while detaching the corners.
    Patrick Nantel - Yanıt
  8. Google Pixel 4a 5G Battery Replacement: adım 8, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 8, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 8, 3 resimden 3.
    • Insert another opening pick into the top edge of your phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Use the pick to slice around the top-left corner where the camera window is.
    • If the screen is hard to slice, apply heat to the difficult area for one minute and try again.
    • Leave the pick inserted along the left edge of your phone to prevent the adhesive from re-sealing.
  9. Google Pixel 4a 5G Battery Replacement: adım 9, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 9, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 9, 3 resimden 3.
    • Slide the opening pick to cut the adhesive along the left edge of your phone.
    • Keep in mind that you are now slicing near the screen flex cable and digitizer.
  10. Google Pixel 4a 5G Battery Replacement: adım 10, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 10, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 10, 3 resimden 3.
    • Slide the opening pick around the bottom-left corner and across the bottom of the display to cut the rest of the adhesive.
  11. Google Pixel 4a 5G Battery Replacement: adım 11, 2 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 11, 2 resimden 2.
    • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, partially opening the phone like a book.
    • Do not remove the screen yet.
    • Use an opening pick to carefully cut through any remaining adhesive.
  12. Google Pixel 4a 5G Battery Replacement, Flip the screen over: adım 12, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Flip the screen over: adım 12, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Flip the screen over: adım 12, 3 resimden 3.
    • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
    • Be careful not to put any stress on the attached ribbon cable.
  13. Google Pixel 4a 5G Battery Replacement, Disconnect the display: adım 13, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Disconnect the display: adım 13, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Disconnect the display: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use your fingernail or a pair of tweezers to carefully peel off the tape covering the screen connector.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of Kapton tape.
    The replacement screen I purchased from iFixit Oceania in Sept 2022 included a new piece of tape.
    Chris - Yanıt
  14. Google Pixel 4a 5G Battery Replacement: adım 14, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 14, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 14, 3 resimden 3.
    • Insert the tip of a spudger into the opening of the plastic cover securing the screen flex cable.
    • Pry the plastic cover straight up until it pops out of place.
    • The plastic cover may spring into the air.
    • Remove the plastic cover.
  15. Google Pixel 4a 5G Battery Replacement: adım 15, 2 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 15, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Google Pixel 4a 5G Battery Replacement, Remove the screen: adım 16, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the screen: adım 16, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Remove the screen: adım 16, 3 resimden 3.
    • Remove the screen.
    • To install a new screen:
    • Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
    • If it does, you won't need the top edge adhesive.
    • If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
    • Follow this guide to apply the custom-cut adhesive.
    • Use the third photo as a reference to position your adhesives.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Don't touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    There are four adhesives provided in the current kit provided by ifixit. They have a blue and clear backing with a thin black strip, as shown on here. The adhesives instructions provided in this general guide are not very clear and I messed up my first one, which made the other three useless leading me to just buy a b-7000 adhesive instead. However, for anyone wanting to correctly use the ifixit adhesives, first line up the black strip on the edge of your phone where the screen will rest and peel off the first clear portion. Then peel off the blue portion and you will be left with a thin black adhesive strip. Do this for all four pieces in the configuration shown on the page linked above and then place your screen on, press down gently, then turn the phone screen down and place some books on to provide stronger contact between the adhesive and the new screen. Good luck!
    Graduate Agriculture - Yanıt
    thanks a lot!
    Zurdits -
    That was so much clearer thank you!
    Jason De Dios -
    Super Anleitung. Allerdings habe ich die Kalibriersequenz leider nicht gesehen. Das Display funktioniert, aber der zweifinger Zoom arbeitet nicht. Kann man die Kalibriersequenz neu aufrufen oder was kann ich tun. In manchen Anleitungen steht, das man im Recovery Mode Display Befehle ausführen kann. Ein Werksreset des Pixel 4A 5G hat nicht geholfen.
    Beim ersten Neustart nach der Reparatur wird das Display eine Kalibriersequenz durchlaufen. Berühre das Display dabei nicht, der Touchscreen könnte nicht richtig kalibriert werden, was zu einer schlechten Funktion führen kann.
    Danke im voraus
    SteffenZimmWeimar - Yanıt
    The adhesive strips do not cover the corners, and I guess there is a good chance of dust comming into the device. Had issues with the front camera after the first repair. Maybe the rounded corner strips could be included in the repair kit?
    Michael Bappert - Yanıt
  17. Google Pixel 4a 5G Battery Replacement, Remove the midframe screws: adım 17, 2 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the midframe screws: adım 17, 2 resimden 2.
    Magnetic Project Mat
    $19.95
    • Use a T3 Torx driver to remove the nine 4.4 mm-long screws securing the back cover to the midframe.
    I found 2 extra screws in mine. FYI. (From America)
    L Daniel Wenger - Yanıt
    I also have 11x T3 in a US model. And the two at the bottom near the USB-C port are shorter by ~1mm than the others.
    Erik Sorensen - Yanıt
  18. Google Pixel 4a 5G Battery Replacement, Separate the back cover from the midframe: adım 18, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Separate the back cover from the midframe: adım 18, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Separate the back cover from the midframe: adım 18, 3 resimden 3.
    • Insert an opening pick into the seam between the midframe and the back cover, right above the SIM card slot.
    • Slide the opening pick along the right edge of your phone to release the plastic clips securing the back cover to the midframe.
  19. Google Pixel 4a 5G Battery Replacement: adım 19, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 19, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 19, 3 resimden 3.
    • Continue sliding the opening pick along the top, left, and bottom edges of your phone until all of the plastic tabs securing the back cover to the midframe are released.
  20. Google Pixel 4a 5G Battery Replacement: adım 20, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 20, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 20, 3 resimden 3.
    • Flip your phone over so the back cover is facing up.
    • Carefully swing the back cover up to an upright position.
    • Do not remove the back cover. It is still attached by two ribbon cables.
    • Rest the back cover against an object such as a cardboard box or soda can.
    Be very gentle when removing the back panel, the ribon for the fingerprint broke and I had to wait 4 weeks to obtain it from China
    clem - Yanıt
  21. Google Pixel 4a 5G Battery Replacement, Remove the motherboard bracket: adım 21, 2 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the motherboard bracket: adım 21, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove the seven screws securing the motherboard bracket:
    • Four 4.0 mm-long screws
    • Three 2.1 mm-long screws
    Hi. Thank you for the great Tuto! Do you know where can I find a replacement battery?
    Nicolas AUCONIE - Yanıt
  22. Google Pixel 4a 5G Battery Replacement: adım 22, 2 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 22, 2 resimden 2.
    • Remove the motherboard bracket.
  23. Google Pixel 4a 5G Battery Replacement, Disconnect the battery: adım 23, 2 resimden 1. Google Pixel 4a 5G Battery Replacement, Disconnect the battery: adım 23, 2 resimden 2.
    • Use the tip of a spudger to disconnect the battery cable from the motherboard.
    Keep in mind this cable when putting board back in place
    Ivan Andrijic - Yanıt
  24. Google Pixel 4a 5G Battery Replacement, Remove the back cover: adım 24, 2 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the back cover: adım 24, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the fingerprint sensor cable.
  25. Google Pixel 4a 5G Battery Replacement: adım 25, 2 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 25, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the front sensor array cable.
  26. Google Pixel 4a 5G Battery Replacement: adım 26, 2 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 26, 2 resimden 2.
    • Remove the back cover.
  27. Google Pixel 4a 5G Battery Replacement, Remove the loudspeaker tape: adım 27, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the loudspeaker tape: adım 27, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Remove the loudspeaker tape: adım 27, 3 resimden 3.
    • Use a pair of tweezers to remove the black tape covering the antenna flex cable between the loudspeaker and the battery.
    • Be careful not to puncture the battery with your tweezers.
  28. Google Pixel 4a 5G Battery Replacement, Access the stretch-release adhesive pull tabs: adım 28, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Access the stretch-release adhesive pull tabs: adım 28, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Access the stretch-release adhesive pull tabs: adım 28, 3 resimden 3.
    • Flip the midframe over.
    • Use a pair of tweezers to remove the rectangular piece of copper foil closest to the edge of the phone.
    • If the copper foil remains intact, reuse it during reassembly. If not, replace it with a piece of Kapton tape.
  29. Google Pixel 4a 5G Battery Replacement: adım 29, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 29, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 29, 3 resimden 3.
    • Use a pair of tweezers to remove the rectangular piece of copper foil closest to the center of the phone.
  30. Google Pixel 4a 5G Battery Replacement, Remove the stretch-release adhesive: adım 30, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the stretch-release adhesive: adım 30, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Remove the stretch-release adhesive: adım 30, 3 resimden 3.
    • Use the flat end of a spudger to lift up the battery adhesive pull tab so that you can reach it with your fingers.
    • Try to keep the adhesive strips flat and unwrinkled during this procedure; twisted or wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one battery adhesive tab away from the battery, towards the bottom of the phone.
    • Pull steadily, maintaining constant tension on the strip until it slips out from between the battery and the midframe. For best results, pull the strip at as low of an angle as possible.
    • The strip will stretch to many times its original length. Continue pulling and re-grab the strip near the battery if necessary.
    • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  31. Google Pixel 4a 5G Battery Replacement: adım 31, 3 resimden 1. Google Pixel 4a 5G Battery Replacement: adım 31, 3 resimden 2. Google Pixel 4a 5G Battery Replacement: adım 31, 3 resimden 3.
    • Repeat the instructions in the previous step for the second stretch-release adhesive strip.
    • If any of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of 90% isopropyl alcohol into the opening of the affected tab and tilt the phone towards the top edge so that the alcohol flows toward the remaining adhesive. Wait one minute for the adhesive to soften, then proceed to the next step.
  32. Google Pixel 4a 5G Battery Replacement, Remove the battery: adım 32, 3 resimden 1. Google Pixel 4a 5G Battery Replacement, Remove the battery: adım 32, 3 resimden 2. Google Pixel 4a 5G Battery Replacement, Remove the battery: adım 32, 3 resimden 3.
    • Do not reuse the battery if it has been deformed or damaged, as doing so is a potential safety hazard. Replace it with a new battery.
    • Insert an opening pick into the battery well along one of the long edges of the battery.
    • Pry the battery upward to remove it from the battery well.
    • If the adhesive was successfully removed, the battery should come out very easily.
    • If the battery cannot be easily extracted due to unsuccessful removal of the stretch-release adhesive, apply 90% isopropyl alcohol as directed in the previous step.
    • Once you have allowed one minute for the alcohol to soften the adhesive, use an opening pick to pry up the battery from one of the long edges.
    • Do not bend the battery as you pull it out.
    My 4a 5g had additional flex cable that appeared to be for the side grip sensors i had to remove.
    Greg Besack - Yanıt
    The battery that iFixit sent me is about 3 mm wider than original pixel 4a 5g. It doesn't fit. These instructions are missing a step. The 4a 5G has a silver ribbon on top of battery that needs removed prior to removing battery.
    Rob Levy - Yanıt
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
85.261 İtibar
290 adet Kılavuz yazıldı
10Kılavuz Yorumları
Hi Sam,
Do you know where to actually buy battery replacements for the 4a 5g? It doesn’t seem like it’s available just doing a Google search, and just wondering if you know something I don’t.
Thanks,
Sally
Sally Hoo - Yanıt
Hi Sally,
Not right now, unfortunately. It’s likely a matter of time before they are available, but it’s difficult to predict exactly when—especially with impacted global supply chains. Keep an eye on iFixit and eBay, and check with any repair shops if you haven’t already.
Best of luck,
Sam
Sam Omiotek -
Hi! This guide worked excellently for removing my battery. But I was hoping you could give me a bit of advice.
I disassembled my phone because I got water in it, and I wanted it to dry more effectively. Because my battery is not damaged I was planning on putting it back in now, but your guide warns against this. Is that because there is no more adhesive? Or potentially something else that I could work around?
Thanks! -Ben
Ben Hilton - Yanıt
Hi Ben!
We warn against reusing batteries because they are usually deformed during removal, which increases the chances of a "thermal event" happening in the future. If you were able to remove yours without deforming it at all, then you should be fine to reuse it.
That being said, with internal water exposure a battery replacement is almost always necessary. It depends on the level of contamination. If it were my phone, I would buy a new one. They are not too expensive.
Sam Omiotek -
Hi :)
I have an Ifixit essential toolkit. The guide is excellent but once i read step 22 it states that I need to use a T3 Torx in order to remove the motherboard. Unfortunately my IFIXT includes only Torx T4 and T5, so I was wondering whether i'll be able to unscrew it anyways using what I have or will I necessarily have to buy another kit?
thank you!
Marco
nanter88 - Yanıt
The guide is much appreciated. I'll take better care of this new battery lol
I forgot to put the tab and tape back on the screen connector though, and I don't want to pull the screen back off, so I just have to live in constant fear of it coming out. FAFO.
Torrent Amador - Yanıt
Nice guide!
Be very careful while removing the back plate because the fingerprint ribbon is very fragile!
Don't do the same mistake as me the adhesive for the battery are not the same size, be sure to place it correctly!
Thanks to the author
clem - Yanıt
Where can I get this process done? I don't feel I can do it myself. Jim in PHX...
James D Cathey - Yanıt
This tutorial was very good. Very thorough.
It's worth noting that the "adhesive" which holds the screen to the body is double sided tape. I didn't have to heat it to get it to release. I used my nail to pierce it before using a pick because my nail seems to be stronger and finer than picks are. I could see the OLED pannel was stressed as I rounded into the corners. Be careful getting around the corners.
David Zilio - Yanıt
If you're re-using the screen (and manage not to break it) do you just put it back with the old adhesive strips and does that stick ok? What are the chances or bricking the screen as a first-time ifixer? Anyone care to guesstimate?
Al Skratch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 128
Son 30 gün: 559
Her zaman: 36,227
