Giriş
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the 5G mmWave antenna in your Google Pixel 8a.
The 5G mmWave antenna is only present in the Verizon model (G8HHN) Google Pixel 8a.
You'll need replacement 5GmmWave antenna, back cover, and flash unit adhesives to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the back cover adhesive.
Neye ihtiyacın var
Unplug all cables from your phone.
Completely power off your phone.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
Don't insert your tool under the edges of the camera bump.
Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
Slide the pick to the right, stopping when you reach the right edge of the cameras.
Remove the back cover.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Follow this guide to apply new adhesive and install your back cover.
Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
Bu adımda kullanılan alet:FixMat$36.95
Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
Thirteen 4.3 mm‑long screws
Two 1.9 mm‑long screws
Remove the logic board cover (which has the wireless charging coil connected to it).
Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
Use a Torx Plus 3IP screwdriver to remove the 4.3 mm‑long screw securing the earpiece speaker to the frame.
Use a Torx Plus 3IP screwdriver to remove the two 4.3 mm‑long screws securing the antenna housing.
Use the point of a spudger or your fingernail to pry up and disconnect the press connector just above the battery.
Insert the tip of a spudger under the notch near the top right corner of the logic board and pry up to unclip the board.
Repeat the process to unclip the other side of the board, using the notch to the left of the cameras.
Lift the top edge of the logic board from the frame.
Pull the top edge of the logic board to the right of the frame so the cutouts of the board lift over the vibration motor and protrusions in the frame.
As you pull, guide the charging port out of its recess in the frame.
Apply a suction handle to the left side of the screen with the handle facing down.
Prop up the left side of your phone so it stands upright.
Tilt the logic board down and lay it flat, gently guiding the delicate graphite sheet around the cables.
If the front sensor rubber gasket stayed on the frame or became misaligned, remove it and set it aside.
Check the condition of the thermal pads—they'll be on the bottom of the logic board or the corresponding spot on the right side of the frame.
If you're reusing your logic board and either of the thermal pads are damaged, remove the old pad, clean the surface with highly-concentrated isopropyl alcohol (over 90%), and apply a new pad.
If you have a new logic board and it doesn't come with thermal pads pre-installed, apply the new pads now.
Insert the point of your spudger under the lower left corner of the 5G mmWave antenna and pry up to separate its adhesive.
Grab the cable as close to the head of the connector as possible and pry the connector away from the antenna to disconnect it.
Lift the 5G mmWave antenna cable upward and peel it from the antenna.
The 5G mmWave antenna is all that remains.
Peel and remove the conductive tape from the head of the cable.
Peel your replacement adhesive off of the large liner.
Remove the two red liners to expose the sticky side of the adhesive.
To reassemble your device, follow these instructions in reverse order, starting with this step.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
