Ana içeriğe geç
Google Pixel 8a Screen Replacement
Spencer Day
Spencer Day ve 3 diğer katkıda bulunanlar
En son April 11, 2025 tarihinde güncellendi
1 - 2 saat
Orta
Öne Çıkan Kılavuzlar
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken, cracked, or unresponsive screen on your Google Pixel 8a.
To calibrate the display’s fingerprint reader, follow this guide. Genuine Google replacement screens come with the fingerprint reader already attached. If your replacement screen doesn’t have a pre-installed fingerprint reader, you’ll need to transfer the original fingerprint reader to your new screen and recalibrate it to retain functionality.
You'll need replacement screen adhesives in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
  1. Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 8a Screen Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
    Mein Bildschirm ist schwarz - das Smartphone reagiert jedoch. Wie kann ich es ausschalten wenn ich kein Bild nicht sehe?
    Ulises - Yanıt
  2. Google Pixel 8a Screen Replacement, Tape over any cracks: adım 2, 2 resimden 1. Google Pixel 8a Screen Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    If the glass is broken, the suction cup will not adhere.
    Justin Santa Barbara - Yanıt
  3. Google Pixel 8a Screen Replacement, Soften the top edge adhesive: adım 3, 1 resimden 1.
    • The screen is strongly adhered to the frame, has no clips, and resists flexing. It requires significant heat to soften the adhesive underneath.
    • Use a hair dryer, heat gun, or hot plate to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
  4. Google Pixel 8a Screen Replacement, Insert your tool under the screen: adım 4, 2 resimden 1. Google Pixel 8a Screen Replacement, Insert your tool under the screen: adım 4, 2 resimden 2.
    • Apply a suction handle to the center of the top edge of the screen.
  5. Google Pixel 8a Screen Replacement: adım 5, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 5, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Jimmy
    $7.95
    • Inserting your tool is very difficult. Be patient and reheat the screen at any point if it feels stuck.
    • Don't insert your tool deeper than 2 mm, as you risk damaging the front-facing camera.
    • Insert the tip of a Jimmy into the left side of the earpiece speaker cutout.
    • If you don't have a Jimmy, you can use another small metal tool. Make sure it's thin and rigid.
    • Pull up on the suction handle with a strong, steady force.
    • Firmly press the Jimmy into the cutout and lower it until the tip slides under the glass.
  6. Google Pixel 8a Screen Replacement: adım 6, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 6, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 6, 3 resimden 3.
    • Insert the tip of an opening pick under the screen and remove the Jimmy.
  7. Google Pixel 8a Screen Replacement, Separate the screen adhesive: adım 7, 3 resimden 1. Google Pixel 8a Screen Replacement, Separate the screen adhesive: adım 7, 3 resimden 2. Google Pixel 8a Screen Replacement, Separate the screen adhesive: adım 7, 3 resimden 3.
    • Don't insert your pick deeper than 2 mm, as you might damage the front-facing camera.
    • Slide your pick back and forth across the top edge of the screen to separate the adhesive.
  8. Google Pixel 8a Screen Replacement: adım 8, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 8, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 8, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm, as you might damage your phone's internal components.
    • For a visual reference, you can measure 3 mm from the tip and mark your pick with a permanent marker.
    • Continue sliding your pick around the perimeter of the phone to separate the remaining adhesive.
    Könnt ihr am Plektrum abschnitte für die Millimeter direkt draufdrucken?
    Lukas Schmidt - Yanıt
    Hier wurde einen Schritt vergessen. Es gibt noch Klebstoff unten mittig unter der Bildschirm. Diese muss auch vorsichtig abgemacht werden. Mein Bildschirm hat sich delaminiert beim Abbau.
    dsavio93 - Yanıt
  9. Google Pixel 8a Screen Replacement: adım 9, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 9, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 9, 3 resimden 3.
    • Swing the right edge of the screen open (like turning the page of a book) and lay it over the left edge of the frame.
    • Be careful not to strain the screen cable.
  10. Google Pixel 8a Screen Replacement, Disconnect the screen: adım 10, 2 resimden 1. Google Pixel 8a Screen Replacement, Disconnect the screen: adım 10, 2 resimden 2.
    • Move the flap of graphite film away from the screen connector.
  11. Google Pixel 8a Screen Replacement: adım 11, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 11, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 11, 3 resimden 3.
    • Hold one hand above the display bracket when prying it up, as the bracket can easily eject.
    • Use the tip of one arm of your angled tweezers to pry up the top edge of the display cable bracket from the center of the logic board.
    • Be very careful not to damage the board under the bracket's socket. Only insert your tweezers just enough to pry up the bracket.
    • Remove the bracket.
  12. Google Pixel 8a Screen Replacement: adım 12, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 12, 2 resimden 2.
    • Insert the tip of a spudger or a clean fingernail under the top edge of the display cable press connector and pry straight up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  13. Google Pixel 8a Screen Replacement: adım 13, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 13, 2 resimden 2.
    • Use tweezers or your fingers to pull the screen cable out from under its lip on the edge of the frame.
  14. Google Pixel 8a Screen Replacement: adım 14, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 14, 2 resimden 2.
    • Remove the screen.
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  15. Google Pixel 8a Screen Replacement: adım 15, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 15, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 15, 3 resimden 3.
    • The remaining steps show how to install your replacement screen.
    • Make sure the front sensor gasket (located just below the front camera) is properly aligned and fully over the sensor.
    • If it's not, reposition it over the front sensor with the smaller cutout toward the top.
  16. Google Pixel 8a Screen Replacement, Prepare the frame for reassembly: adım 16, 2 resimden 1. Google Pixel 8a Screen Replacement, Prepare the frame for reassembly: adım 16, 2 resimden 2.
    • The underside of the battery is exposed through a small cutout in the frame—be careful not to damage it with your tool.
    • Use tweezers and a spudger to scrape up and remove any remaining pieces of adhesive below the battery cutout.
  17. Google Pixel 8a Screen Replacement: adım 17, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 17, 2 resimden 2.
    • If any screen adhesive bits remain on the perimeter of the frame, use a spudger and tweezers to scrape up and remove them.
  18. Google Pixel 8a Screen Replacement: adım 18, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 18, 2 resimden 2.
    • If you're reusing your original screen, use a spudger and tweezers to scrape up and remove the old adhesive from the perimeter of the screen.
  19. Google Pixel 8a Screen Replacement: adım 19, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 19, 2 resimden 2.
    Microfiber Cleaning Cloths
    $3.99
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame and the area below the battery cutout.
    • Wipe the residue away using a lint-free or microfiber cloth.
  20. Google Pixel 8a Screen Replacement, Apply new adhesives: adım 20, 2 resimden 1. Google Pixel 8a Screen Replacement, Apply new adhesives: adım 20, 2 resimden 2.
    • Peel the rectangular display enclosure adhesive from its large liner.
    • Apply the adhesive to the frame in the same location as the old adhesive, just below the battery cutout.
    • Use the white line on the frame to help align the right edge.
    • Use your fingers to press down and secure the adhesive to the frame—don't remove the top liner yet.
  21. Google Pixel 8a Screen Replacement: adım 21, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 21, 2 resimden 2.
    • If your screen already comes with adhesive pre-installed, remove its liner and skip down six steps to continue reassembly.
    • Before removing any liners from the screen adhesive, hold it over the frame to make sure it's oriented correctly. Use the camera cutout on the top edge to line it up correctly.
    • The blue liner should be facing up, with the larger, clear liner on the bottom.
    It's probably just me, but the large blue sheet looks very similar to other blue protective sheets covering the adhesive. I think it should be stated earlier that it is only the black edge which is the adhesive.
    Or remove these steps into a link and make the newer screens with adhesive the main instruction
    David Loader - Yanıt
  22. Google Pixel 8a Screen Replacement: adım 22, 1 resimden 1.
    • Peel down the top half of the larger liner (closest to the camera cutout) to expose the adhesive—don't remove the whole liner yet.
  23. Google Pixel 8a Screen Replacement: adım 23, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 23, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 23, 3 resimden 3.
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • Keep the larger liner folded towards the bottom of the phone during this step.
    • Lay the exposed top edge of the adhesive onto the frame, using the lip to help align it.
    • Once the top edge is properly aligned, gently press down to secure it in place.
  24. Google Pixel 8a Screen Replacement: adım 24, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 24, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 24, 3 resimden 3.
    • Slowly lay the rest of the adhesive onto the frame, peeling away the large liner as you go.
  25. Google Pixel 8a Screen Replacement: adım 25, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 25, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 25, 3 resimden 3.
    • Use the flat end of your spudger to press along the perimeter of the adhesive and secure it to the frame.
  26. Google Pixel 8a Screen Replacement: adım 26, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 26, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 26, 3 resimden 3.
    • Grab the pull tab in the center of the left edge and slowly peel and remove the liner.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
  27. Google Pixel 8a Screen Replacement, Reattach the screen: adım 27, 2 resimden 1. Google Pixel 8a Screen Replacement, Reattach the screen: adım 27, 2 resimden 2.
    • Apply a suction handle to the left side of the replacement screen, with the handle facing left.
    • Prop up your screen on the left side of the frame.
    • If you don't have a suction handle, prop up the phone against a sturdy object, such as a heavy box or thick book.
  28. Google Pixel 8a Screen Replacement: adım 28, 1 resimden 1.
    • Connect the screen cable by aligning it over the socket and pressing on one side until it clicks into place before fully pressing it down.
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    My screen shows the google animation bootup in very tinted yellow and dim/dark. Then the time appears for less than a second and the screen goes completely black. Did I get a defective part?
    John - Yanıt
    Hi, I hope somebody will be able to give some help. My screen wouldnt turn on after insterting my new screen connector, can anyone give me some advice on where i went wrong?
    Jimmy Lau - Yanıt
    It really should be stressed here to be extremely careful!
    There is almost no feedback through your fingers or tools whether the cable is in the correct position before pressing down.
    100% this was the hardest/nerve-wracking part of the job
  29. Google Pixel 8a Screen Replacement: adım 29, 2 resimden 1. Google Pixel 8a Screen Replacement: adım 29, 2 resimden 2.
    • Hook the bottom edge of the bracket into its slot on the logic board and press down firmly on the top to snap the bracket back into place.
    • If your display cable bracket is bent and doesn't fit, replace it with a new one.
  30. Google Pixel 8a Screen Replacement, Remove the liners: adım 30, 1 resimden 1.
    • Remove any liners from the front camera housing on the top edge of the screen.
  31. Google Pixel 8a Screen Replacement: adım 31, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 31, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 31, 3 resimden 3.
    • Peel and remove the blue liner from the square adhesive on the frame, just below the battery cutout.
  32. Google Pixel 8a Screen Replacement: adım 32, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 32, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 32, 3 resimden 3.
    • Use the pull tabs on the left edge to peel and remove the remaining perimeter adhesive liner.
  33. Google Pixel 8a Screen Replacement, Secure the new screen: adım 33, 3 resimden 1. Google Pixel 8a Screen Replacement, Secure the new screen: adım 33, 3 resimden 2. Google Pixel 8a Screen Replacement, Secure the new screen: adım 33, 3 resimden 3.
    • Hold the screen just above the frame by the suction handle.
    • Use a spudger to fold the flap of graphite film back over the screen cable.
    • Press the screen into place.
  34. Google Pixel 8a Screen Replacement: adım 34, 3 resimden 1. Google Pixel 8a Screen Replacement: adım 34, 3 resimden 2. Google Pixel 8a Screen Replacement: adım 34, 3 resimden 3.
    • Remove the suction handle.
    • For a better seal, lightly warm the screen with a heated iOpener, hair dryer, heat gun, or hot plate before pressing around the perimeter.
    • Firmly press around the perimeter of the screen to secure it to the frame.
Sonuç
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
27 farklı kişi bu kılavuzu tamamladı.
Spencer Day
104.255 İtibar
740 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.776 adet Kılavuz yazıldı
13Kılavuz Yorumları
so where is the replacement screens??
lsdfkgjlsdfjkl - Yanıt
You can purchase a new screen from iFixit here.
Spencer Day -
Great step by step guide, it took a little time but was well worth it with my busted screen!
Kabel - Yanıt
I think my screen was defective. It shows the boot up animation extremely yellowed out and dim/dark. Then it shows my lockscreen with the time for less than a second and goes complete black. I can still make my phone vibrate with the buttons, and do a reset to get the boot up animation again. It's just so frustrating because I really needed this to work and did so much of the hard work to get to the final steps, to find out... that the replacement screen is defective!!!!
John - Yanıt
Hi John. I'm sorry to hear you're having issues with the replacement screen—that's very frustrating after taking the time to do the repair. My first thought is that the screen connector may not be fully seated (this connector in particular can be quite tricky to reconnect). If that's not the case, you can contact our customer support (support@ifixit.com) about a defective screen.
Spencer Day -
I've contacted support and they have yet to get back to me. I will be initiating a return. I don't think I would have attempted this repair again, taking the screen off was far far more difficult than it's worth. I'd take it to a repair shop.
John -
Excellent support and great company. I had a problem with the fingerprint sensor, which after starting it up indicated that it was faulty. I requested a replacement and everything went great. Thanks!
Carles Gomez - Yanıt
You should add the part to recalibrate the fingerprint (pixelrepair.withgoogle.com/udfps) in your tutorial.
Bruno Spolidorio - Yanıt
Thank you so much! As a first time screen repairer, it wasn't clear to me how deep I should insert the jimmy in the earpiece cutout. The screen assembly is much thinner than I imagined. Also, the screen was badly cracked so removal was overall messy. In the end I figured it out and after that it was all smooth sailing, but some additional clarifying notes in that section might be useful :)
Marco Baggio - Yanıt
That's exactly what happened to me. I was super frustrated with their manual. to be honest, i'm not sure I'd choose this option again.
Tal Givati -
Did this as my first screen repair. Thanks heaps Spencer.
The only feedback I would suggest for this manual is how to handle massively cracked edges. Non cracked edges separated easily, but the blue pick looses its way when it gets to the cracked edges - I had a few - and for my first screen repair I was stuck.
I did end up applying some heat, and using the tweezers to carefully pry the screen away from the phone by grabbing the backing of the screen where it was stable. This worked. Most of the glass complied with the tweezers/heat method. The left over glass stuck to the frame was easy to remove with the spudger. Please let me know if there was a better way to do this.
The pixel 8a I have cost me $679 on special from JB-HifI. A local repairer quote me $700 - $800 to fix the screen - but I had to commit to a $99 diagnostic fee first.
Much much cheaper to fix it myself.
Thanks again!
Julius Csepregi - Yanıt
Attempting this repair with the full ifixit kit has been a disaster. First off, the guide is not fit for purpose - if you have any cracks that run to the edge of the screen it is impossible to proceed past them with undoing the glue rim. Trying to just shatters the glass further. Also the suction cup is useless, does not adhere at all, even when using the tape as described. Now I have a completely broken phone screen that I cannot even use to recover the data (I should have backed up, but seemed like an easy enough repair for someone who has already had experience with these) and then I have an unused new screen i have no use for as I cannot repair this phone anymore. Urgh... 1/10 !!
Maciej Jabłoński - Yanıt
A few days after the repair I wanted to put on a protective glass. I applied more then usual pressure on the screen and now my screen has a white stripe top to bottom and it does not react properly to my touch. Any idea as to what happened or how to fix it? Helpp!
Ulises - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 78
Son 7 gün: 650
Son 30 gün: 3,011
Her zaman: 22,656
