Ana içeriğe geç
HP 15-ac158dx Keyboard Replacement
Onose Aigbe
Onose Aigbe ve 6 diğer katkıda bulunanlar
En son January 16, 2025 tarihinde güncellendi
45 dakika - 1 saat
Orta
Daha iyi giriş
Eksik Ayrıntılar
This Guide will walk you through replacing your keyboard on a HP 15-ac158dx Laptop. This is not an easy process, so you will want to pull out your plastic prying tools and Philips J00 Screw Driver and follow the instructions closely.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. HP 15-ac158dx Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac158dx Keyboard Replacement: adım 2, 1 resimden 1.
    • Turn off the computer by holding the power button.
  3. HP 15-ac158dx Keyboard Replacement: adım 3, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 3, 2 resimden 2.
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac158dx Keyboard Replacement: adım 4, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 4, 2 resimden 2.
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac158dx Keyboard Replacement, Back Panel: adım 5, 3 resimden 1. HP 15-ac158dx Keyboard Replacement, Back Panel: adım 5, 3 resimden 2. HP 15-ac158dx Keyboard Replacement, Back Panel: adım 5, 3 resimden 3.
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac158dx Keyboard Replacement: adım 6, 1 resimden 1.
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac158dx Keyboard Replacement: adım 7, 3 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 7, 3 resimden 2. HP 15-ac158dx Keyboard Replacement: adım 7, 3 resimden 3.
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac158dx Keyboard Replacement, CD Compartment: adım 8, 3 resimden 1. HP 15-ac158dx Keyboard Replacement, CD Compartment: adım 8, 3 resimden 2. HP 15-ac158dx Keyboard Replacement, CD Compartment: adım 8, 3 resimden 3.
    • Locate the CD Compartment as shown and gently slide it out.
  9. HP 15-ac158dx Keyboard Replacement, Fan: adım 9, 3 resimden 1. HP 15-ac158dx Keyboard Replacement, Fan: adım 9, 3 resimden 2. HP 15-ac158dx Keyboard Replacement, Fan: adım 9, 3 resimden 3.
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  10. HP 15-ac158dx Keyboard Replacement: adım 10, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 10, 2 resimden 2.
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  11. HP 15-ac158dx Keyboard Replacement: adım 11, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 11, 2 resimden 2.
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  12. HP 15-ac158dx Keyboard Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac158dx Keyboard Replacement: adım 13, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 13, 2 resimden 2.
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac158dx Keyboard Replacement: adım 14, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 14, 2 resimden 2.
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac158dx Keyboard Replacement: adım 15, 1 resimden 1.
    • Remove the motherboard.
  16. HP 15-ac158dx Keyboard Replacement, Keyboard: adım 16, 2 resimden 1. HP 15-ac158dx Keyboard Replacement, Keyboard: adım 16, 2 resimden 2.
    • Remove the Hard Drive.
  17. HP 15-ac158dx Keyboard Replacement: adım 17, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 17, 2 resimden 2.
    • Lift up the cable port and place it to the side but do not remove completely from the laptop.
    • Remove the single Phillips screw securing it first.
  18. HP 15-ac158dx Keyboard Replacement: adım 18, 3 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 18, 3 resimden 2. HP 15-ac158dx Keyboard Replacement: adım 18, 3 resimden 3.
    • Remove the VENDOR component.
    • Unscrew the single Phillips screw holding it to the frame first.
  19. HP 15-ac158dx Keyboard Replacement: adım 19, 2 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 19, 2 resimden 2.
    • Using a plastic prying tools, remove the grey metal plate.
    • It will not come off easy, but do not force it off.
  20. HP 15-ac158dx Keyboard Replacement: adım 20, 3 resimden 1. HP 15-ac158dx Keyboard Replacement: adım 20, 3 resimden 2. HP 15-ac158dx Keyboard Replacement: adım 20, 3 resimden 3.
    • Locate the damaged keyboard and lift up with the prying tool to remove.
    • To put everything back together and use your laptop with the new keyboard, follow the steps in REVERSE..
    • ENJOY :)
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Onose Aigbe
390 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G2
3 Üyeler
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
Did you have to use soldering iron to melt the plastic rivets when putting back the keyboard?
Cheers.
Lo Yuk Fai - Yanıt
I have done these before and yes, using a soldering iron to melt the plastic rivets is a good method.
Richard Ness -
Helpful. Too good!
David Dii Toke - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 107
Her zaman: 6,326
