Ana içeriğe geç
HP 15-dy SSD Replacement
Neye ihtiyacın var
  1. HP 15-dy SSD Replacement, Prepare your laptop for disassembly: adım 1, 1 resimden 1.
    • Fully shut down your laptop and unplug all cables.
  2. HP 15-dy SSD Replacement, Flip your laptop over: adım 2, 1 resimden 1.
    • Flip your laptop over so the rubber feet are facing up.
  3. HP 15-dy SSD Replacement, Peel up an end of the front foot: adım 3, 3 resimden 1. HP 15-dy SSD Replacement, Peel up an end of the front foot: adım 3, 3 resimden 2. HP 15-dy SSD Replacement, Peel up an end of the front foot: adım 3, 3 resimden 3.
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  4. HP 15-dy SSD Replacement, Remove the front foot: adım 4, 3 resimden 1. HP 15-dy SSD Replacement, Remove the front foot: adım 4, 3 resimden 2. HP 15-dy SSD Replacement, Remove the front foot: adım 4, 3 resimden 3.
    • Peel the front foot away from the back cover and remove it.
  5. HP 15-dy SSD Replacement, Remove the rear foot: adım 5, 3 resimden 1. HP 15-dy SSD Replacement, Remove the rear foot: adım 5, 3 resimden 2. HP 15-dy SSD Replacement, Remove the rear foot: adım 5, 3 resimden 3.
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  6. HP 15-dy SSD Replacement, Reassembly information: adım 6, 3 resimden 1. HP 15-dy SSD Replacement, Reassembly information: adım 6, 3 resimden 2. HP 15-dy SSD Replacement, Reassembly information: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $5.99
    Satın Al
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
  7. HP 15-dy SSD Replacement, Unfasten the back cover: adım 7, 2 resimden 1. HP 15-dy SSD Replacement, Unfasten the back cover: adım 7, 2 resimden 2.
    • Use a Phillips screwdriver to remove the eight screws securing the back cover:
    • Six 6.5 mm-long silver screws
    • Two 6.7 mm-long black screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  8. HP 15-dy SSD Replacement, Open your laptop: adım 8, 3 resimden 1. HP 15-dy SSD Replacement, Open your laptop: adım 8, 3 resimden 2. HP 15-dy SSD Replacement, Open your laptop: adım 8, 3 resimden 3.
    • Flip your laptop over and open the screen.
  9. HP 15-dy SSD Replacement, Release the clips: adım 9, 2 resimden 1. HP 15-dy SSD Replacement, Release the clips: adım 9, 2 resimden 2.
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
    • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
  10. HP 15-dy SSD Replacement: adım 10, 2 resimden 1. HP 15-dy SSD Replacement: adım 10, 2 resimden 2.
    • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
    • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
  11. HP 15-dy SSD Replacement: adım 11, 3 resimden 1. HP 15-dy SSD Replacement: adım 11, 3 resimden 2. HP 15-dy SSD Replacement: adım 11, 3 resimden 3.
    • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
    • Slide the opening pick to the bottom left corner to release the remaining clips.
  12. HP 15-dy SSD Replacement, Flip your laptop over: adım 12, 3 resimden 1. HP 15-dy SSD Replacement, Flip your laptop over: adım 12, 3 resimden 2. HP 15-dy SSD Replacement, Flip your laptop over: adım 12, 3 resimden 3.
    • Close the screen and flip your laptop back over again.
  13. HP 15-dy SSD Replacement, Remove the back cover: adım 13, 3 resimden 1. HP 15-dy SSD Replacement, Remove the back cover: adım 13, 3 resimden 2. HP 15-dy SSD Replacement, Remove the back cover: adım 13, 3 resimden 3.
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
  14. HP 15-dy SSD Replacement, Unfasten the battery: adım 14, 2 resimden 1. HP 15-dy SSD Replacement, Unfasten the battery: adım 14, 2 resimden 2.
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
  15. HP 15-dy SSD Replacement, Remove the battery: adım 15, 3 resimden 1. HP 15-dy SSD Replacement, Remove the battery: adım 15, 3 resimden 2. HP 15-dy SSD Replacement, Remove the battery: adım 15, 3 resimden 3.
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  16. HP 15-dy SSD Replacement, Remove the SSD screw: adım 16, 2 resimden 1. HP 15-dy SSD Replacement, Remove the SSD screw: adım 16, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 2.5 mm-long screw securing the SSD.
  17. HP 15-dy SSD Replacement, Remove the SSD: adım 17, 3 resimden 1. HP 15-dy SSD Replacement, Remove the SSD: adım 17, 3 resimden 2. HP 15-dy SSD Replacement, Remove the SSD: adım 17, 3 resimden 3.
    • Grip the SSD by its edges and pull it straight out of its socket to remove it.
    • Don't pull up at a sharp angle, as this could damage the SSD and its socket.
    • During reassembly, if your model has an SSD thermal pad, make sure it's transferred to the replacement SSD.
Sonuç
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
55.203 İtibar
408 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
136 Üyeler
17.430 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 26
Son 30 gün: 146
Her zaman: 1,221
