Ana içeriğe geç
HP Chromebook 11 G8 EE Battery Replacement
Neye ihtiyacın var
  1. HP Chromebook 11 G8 EE Battery Replacement, Keyboard & Touchpad Assembly: adım 1, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove:
    • Four 7 mm screws.
    • Two 8 mm screws.
  2. HP Chromebook 11 G8 EE Battery Replacement: adım 2, 2 resimden 1. HP Chromebook 11 G8 EE Battery Replacement: adım 2, 2 resimden 2.
    • Flip the device over and open the lid.
    • Use a plastic opening tool to pry the keyboard assembly away from the bottom case, prying around the perimeter until it fully separates.
    • Lift the keyboard assembly from the laptop towards you, away from the screen.
  3. HP Chromebook 11 G8 EE Battery Replacement: adım 3, 3 resimden 1. HP Chromebook 11 G8 EE Battery Replacement: adım 3, 3 resimden 2. HP Chromebook 11 G8 EE Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift the keyboard ribbon lock bar and use tweezers to disconnect the keyboard ribbon from the motherboard.
    • Lift the lock bar and use tweezers to remove the touchpad ribbon.
    • Remove the keyboard.
  4. HP Chromebook 11 G8 EE Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Do not puncture or damage any parts of the battery.
    • Disconnect the battery cable from the motherboard by pulling the connector straight out of its motherboard port.
    • The speakers are removed in these images, but they don't need to be to replace the battery.
  5. HP Chromebook 11 G8 EE Battery Replacement: adım 5, 3 resimden 1. HP Chromebook 11 G8 EE Battery Replacement: adım 5, 3 resimden 2. HP Chromebook 11 G8 EE Battery Replacement: adım 5, 3 resimden 3.
    • Remove the four 3.5 mm Phillips #1 screws securing the battery.
    • If you've already removed the speakers, you'll only need to remove the two screws on the top of the battery, near the motherboard.
  6. HP Chromebook 11 G8 EE Battery Replacement: adım 6, 2 resimden 1. HP Chromebook 11 G8 EE Battery Replacement: adım 6, 2 resimden 2.
    • Carefully lift the battery up and out.
Sonuç
Julia Latura
328 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 UMass Dartmouth, Team 4-2, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S4G2
5 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 14
Son 30 gün: 48
Her zaman: 788
