Ana içeriğe geç
HP Compaq C700 Touchpad Replacement
Taylor Johansen
Taylor Johansen ve 5 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
1 saat
Zor
To remove the touchpad, you must remove other components to get to it such as the keyboard.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. HP Compaq C700 Touchpad Replacement, Keyboard: adım 1, 1 resimden 1.
    • It is advised to work on the device only when it is powered off so as to avoid electrocution risks.
    • Turn off computer by pressing and holding the power button.
  2. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 1. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 2. HP Compaq C700 Touchpad Replacement: adım 2, 3 resimden 3.
    • Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
    • Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
  3. HP Compaq C700 Touchpad Replacement: adım 3, 1 resimden 1.
    • Gently lift up and remove the keyboard.
  4. HP Compaq C700 Touchpad Replacement, Touchpad: adım 4, 1 resimden 1.
    • Locate the twenty 3 mm Phillips head screws.
    • Unscrew them using the PH0 screwdriver.
  5. HP Compaq C700 Touchpad Replacement: adım 5, 1 resimden 1.
    • Remove the hard drive by pulling on the plastic tab and lifting upward.
  6. HP Compaq C700 Touchpad Replacement: adım 6, 1 resimden 1.
    • Locate and unscrew the two Phillips head 3 mm screws on the wireless card.
  7. HP Compaq C700 Touchpad Replacement: adım 7, 1 resimden 1.
    • Unhook the two wires connecting to the wireless card by gently pulling them out.
  8. HP Compaq C700 Touchpad Replacement: adım 8, 1 resimden 1.
    • Gently lift and pull out the card.
  9. HP Compaq C700 Touchpad Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Locate the power button connector wire.
    • Using the tweezers, unhook the wire.
  10. HP Compaq C700 Touchpad Replacement: adım 10, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 10, 2 resimden 2.
    • Press and hold the lock to pop the panel piece above the keyboard and pull up to remove it.
  11. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 1. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 2. HP Compaq C700 Touchpad Replacement: adım 11, 3 resimden 3.
    • Unplug the remaining wires using the tweezers.
  12. HP Compaq C700 Touchpad Replacement: adım 12, 1 resimden 1.
    • Gently pull out the three wires.
  13. HP Compaq C700 Touchpad Replacement: adım 13, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 13, 2 resimden 2.
    • Locate the four 3 mm Phillips head screws.
  14. HP Compaq C700 Touchpad Replacement: adım 14, 1 resimden 1.
    • Unhook the display connector wire.
  15. HP Compaq C700 Touchpad Replacement: adım 15, 1 resimden 1.
    • Gently disconnect the display by pulling it upwards.
  16. HP Compaq C700 Touchpad Replacement: adım 16, 1 resimden 1.
    • Locate the disk drive on the side of the device.
    • Remove it by pulling it all the way out.
  17. HP Compaq C700 Touchpad Replacement: adım 17, 1 resimden 1.
    • Use the PH0 screwdriver to remove the two 3 mm Phillips head screws in the disk drive port.
  18. HP Compaq C700 Touchpad Replacement: adım 18, 1 resimden 1.
    • Disconnect the touchpad connection using the tweezers.
  19. HP Compaq C700 Touchpad Replacement: adım 19, 1 resimden 1.
    • Use the plastic opening tool to pry up all sides of the device cover.
  20. HP Compaq C700 Touchpad Replacement: adım 20, 1 resimden 1.
    • Remove the cover by lifting it.
  21. HP Compaq C700 Touchpad Replacement: adım 21, 1 resimden 1.
    • Use the PH0 screwdriver to remove the six 1 mm Phillips head screws surrounding the touchpad
  22. HP Compaq C700 Touchpad Replacement: adım 22, 1 resimden 1.
    • Use the tweezers to remove the touchpad wire connection.
  23. HP Compaq C700 Touchpad Replacement: adım 23, 2 resimden 1. HP Compaq C700 Touchpad Replacement: adım 23, 2 resimden 2.
    • Use the plastic opening tool to pry up the touchpad cover.
    • Lift and remove the touchpad cover.
  24. HP Compaq C700 Touchpad Replacement: adım 24, 1 resimden 1.
    • Use the blow dryer to melt the adhesive around the edge of the touchpad.
    • The touchpad is now free to be removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Taylor Johansen
690 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-6, Martin Fall 2016 UMass Dartmouth, Team 5-6, Martin Fall 2016 üyesi
UMASSD-MARTIN-F16S5G6
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
I need Compaq laptop c700 Touch pad
So how can I get it?
Suraj Verma - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 11
Her zaman: 1,413
