Ana içeriğe geç
HP Elite X2 1013 G3 Battery Replacement
Asmita Sharma
Asmita Sharma ve 5 diğer katkıda bulunanlar
En son April 5, 2024 tarihinde güncellendi
10 dakika
Kolay
If the battery on your laptop no longer holds charge or otherwise needs replacement, use this guide to remove and replace it.
If your battery appears to be swollen, please see iFixits related Wiki.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: adım 1, 1 resimden 1.
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: adım 2, 2 resimden 1. HP Elite X2 1013 G3 Battery Replacement: adım 2, 2 resimden 2.
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: adım 3, 2 resimden 1. HP Elite X2 1013 G3 Battery Replacement: adım 3, 2 resimden 2.
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: adım 4, 2 resimden 1. HP Elite X2 1013 G3 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery out of the housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Asmita Sharma
186 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G12, Maness Spring 2019 Cal Poly, Team S9-G12, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G12
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 37
Her zaman: 2,965
