Ana içeriğe geç
HP EliteBook 8440p Keyboard Replacement
Michael Uytingco
Michael Uytingco ve 3 diğer katkıda bulunanlar
En son March 20, 2025 tarihinde güncellendi
10 - 25 dakika
Kolay
Are keys on your HP EliteBook 8440p laptop keyboard broken, stuck, or dirty? It might be time to replace your keyboard, and this guide will teach you how to do it yourself! Removing the keyboard is also a crucial step to getting inside the computer to make repairs or clean.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. HP EliteBook 8440p Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. HP EliteBook 8440p Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. HP EliteBook 8440p Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Before you begin, unplug all cables and devices from the laptop.
    • Lay the laptop on its cover.
  2. HP EliteBook 8440p Keyboard Replacement: adım 2, 2 resimden 1. HP EliteBook 8440p Keyboard Replacement: adım 2, 2 resimden 2.
    • Release the battery by pulling the battery tab to the left.
    • Remove the battery.
    • The battery is already removed in the reference image.
  3. HP EliteBook 8440p Keyboard Replacement: adım 3, 3 resimden 1. HP EliteBook 8440p Keyboard Replacement: adım 3, 3 resimden 2. HP EliteBook 8440p Keyboard Replacement: adım 3, 3 resimden 3.
    • With a Phillips-head screwdriver, unscrew the three screws marked with the keyboard icon.
    • Do not remove the screws from the casing; they are built to stay in when loose.
  4. HP EliteBook 8440p Keyboard Replacement: adım 4, 3 resimden 1. HP EliteBook 8440p Keyboard Replacement: adım 4, 3 resimden 2. HP EliteBook 8440p Keyboard Replacement: adım 4, 3 resimden 3.
    • Turn the laptop over and open the cover.
    • Push down the little clips located between the Function Keys to release the top of the keyboard. Lift the keyboard gently with a forward and upward motion.
    • Rest the keyboard over the touch pad.
    • When reassembling, line up the tabs at the keyboard's base with the casing's slots and reverse the motion.
    The tabs at the top of the keyboard need to be slid towards the center to release it.
    Timothy Koulik - Yanıt
  5. HP EliteBook 8440p Keyboard Replacement: adım 5, 1 resimden 1.
    • Using a spudger or flat-head screwdriver, pull up the tabs at the black ribbon cable's sides to unlock the cable.
  6. HP EliteBook 8440p Keyboard Replacement: adım 6, 2 resimden 1. HP EliteBook 8440p Keyboard Replacement: adım 6, 2 resimden 2.
    • Pull the black ribbon cable out of its slot.
  7. HP EliteBook 8440p Keyboard Replacement: adım 7, 1 resimden 1.
    • Using a spudger or flat-head screwdriver, pull up the tabs at the white ribbon cable's sides to unlock the cable.
  8. HP EliteBook 8440p Keyboard Replacement: adım 8, 2 resimden 1. HP EliteBook 8440p Keyboard Replacement: adım 8, 2 resimden 2.
    • Pull the white ribbon cable out of its slot.
  9. HP EliteBook 8440p Keyboard Replacement: adım 9, 1 resimden 1.
    • Remove the keyboard from the laptop.
Sonuç
23 farklı kişi bu kılavuzu tamamladı.
Michael Uytingco
831 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-2, Green Fall 2015 Cal Poly, Team 10-2, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G2
3 Üyeler
3 adet Kılavuz yazıldı
5Kılavuz Yorumları
The top of the keyboard has locking tabs that need to be pulled back towards the keyboard center or it won't come out. They hold the replacement keyboard in place long enough to get the screws into it.
Robert Taylor - Yanıt
But you don’t need to remove the battery.
Jakub Daszkiewicz - Yanıt
Taking it out was easy, putting a new one in- just impossible, brackets very brittle and cracking. Had to give it to the shop to fix it.
zbig j - Yanıt
Perfect guide except for keyboard tabs mentioned in comment from Robert Taylor! Well done!
Dave Tennant - Yanıt
PERFECT! It took me 15 minutes to replace the keyboard!
Victor Torkornoo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 18,150
