Ana içeriğe geç
HP EliteBook 8470p Case/Service Cover Replacement
Owen Bangs
Owen Bangs ve 2 diğer katkıda bulunanlar
En son December 21, 2022 tarihinde güncellendi
25 saniye
Çok kolay
The service cover protects the internal components of the laptop. It also allows for easy access for servicing the internal components.
  1. HP EliteBook 8470p Case/Service Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Case/Service Cover Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Case/Service Cover Replacement: adım 3, 1 resimden 1.
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Case/Service Cover Replacement, Case/Service Cover: adım 4, 1 resimden 1.
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Case/Service Cover Replacement: adım 5, 2 resimden 1. HP EliteBook 8470p Case/Service Cover Replacement: adım 5, 2 resimden 2.
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Owen Bangs
660 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 33
Her zaman: 571
