Ana içeriğe geç
HP EliteBook 8470p Memory/RAM Replacement
Bryce Martin
Bryce Martin ve 3 diğer katkıda bulunanlar
En son December 21, 2022 tarihinde güncellendi
10 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
The Memory Module or RAM in this computer is responsible for the temporary storage of memory that is wiped when the computer is turned off. RAM is accessed when you call on your computer to open apps or surf the web.
Reasons that your RAM would stop working are if the board is faulty, if it is not installed correctly or if there is excessive dust that is causing the connection to not be clean.
Before starting this step the battery and service cover will need to be removed from the bottom of the computer.
WARNING: if the BIOS is not up to date before removing the RAM, the system could inherit many different problems. See https://support.hp.com/us-en/document/c0... for more information on how to complete this process.
  1. HP EliteBook 8470p Memory/RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Position the computer upside down with the opening latch facing away from you and the battery facing towards you.
    • If the battery is “swollen” or the shape is irregular, stop whatever you are doing and allow the battery to slowly discharge itself before removing it from the laptop casing. Click the link to learn how to replace and dispose of a “swollen” battery, What to do with a swollen battery.
  2. HP EliteBook 8470p Memory/RAM Replacement: adım 2, 1 resimden 1.
    • Slide the battery latch positioned to the right over to the right side. Hold it there.
  3. HP EliteBook 8470p Memory/RAM Replacement: adım 3, 1 resimden 1.
    • With the latch opened, pull the battery out of its socket firmly.
    • There will likely be some resistance. However, if you find it to be excessive, the latch may not be properly opened.
  4. HP EliteBook 8470p Memory/RAM Replacement, Case/Service Cover: adım 4, 1 resimden 1.
    • With the laptop latch still facing away from you, slide the left release latch to the left.
    • Some models may have a screw installed on this latch, if so, be sure to remove it first to avoid damaging the latch.
  5. HP EliteBook 8470p Memory/RAM Replacement: adım 5, 2 resimden 1. HP EliteBook 8470p Memory/RAM Replacement: adım 5, 2 resimden 2.
    • Slide the door away from you, toward the opening latch.
    • Lift the door upwards away from the computer.
    • CAUTION: Before removing the memory module, update to the latest BIOS. Failure to do so could result in various system problems.
  6. HP EliteBook 8470p Memory/RAM Replacement: adım 7, 1 resimden 1.
    • Spread the retaining tabs on either side of the memory module to release the module.
  7. HP EliteBook 8470p Memory/RAM Replacement: adım 8, 2 resimden 1. HP EliteBook 8470p Memory/RAM Replacement: adım 8, 2 resimden 2.
    • Remove the memory module by pulling the module away from the slot at an angle.
  8. HP EliteBook 8470p Memory/RAM Replacement: adım 9, 3 resimden 1. HP EliteBook 8470p Memory/RAM Replacement: adım 9, 3 resimden 2. HP EliteBook 8470p Memory/RAM Replacement: adım 9, 3 resimden 3.
    • Note that the device does have two memory slots. The top slot houses the the expansion memory and the bottom slot houses the primary memory.
    • Repeat the previous steps if there is an expansion memory card
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bryce Martin
122 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 UMass Dartmouth, Team 5-3, Sinclaire Fall 2022 üyesi
UMASSD-SINCLAIRE-F22S5G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 32
Her zaman: 859
