Ana içeriğe geç
HP EliteBook x360 1030 G3 Keyboard Replacement
Moses Cung
Moses Cung ve 3 diğer katkıda bulunanlar
En son December 10, 2023 tarihinde güncellendi
15 dakika
Kolay
This guide is to show how to replace the keyboard for the HP EliteBook x360 1030 G3. A broken keyboard makes the computer essentially useless and replacing it can allow you to extend the life of your computer.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. HP EliteBook x360 1030 G3 Keyboard Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 2, 1 resimden 1.
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Keyboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 4, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 4, 2 resimden 2.
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out of its place.
  6. HP EliteBook x360 1030 G3 Keyboard Replacement, Fan: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
    • Use the same screwdriver to remove the remaining five 3.9 mm screws.
  7. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 7, 3 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 7, 3 resimden 2. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 7, 3 resimden 3.
    • Before pulling the fan out, identify the two wires that are connected to the fan and to the motherboard.
    • For each, use plastic opening tool to lift the black wire housing upward out of its port.
    • Be sure not to pull the wires; doing so may cause damage.
  8. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 8, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 8, 2 resimden 2.
    • Slide the fan assembly toward you, and when the top edge of the fan is out of the vent grill, the fan is completely removed.
  9. HP EliteBook x360 1030 G3 Keyboard Replacement, Solid State Drive: adım 9, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement, Solid State Drive: adım 9, 2 resimden 2.
    • Lift the black tape covering the solid state drive.
  10. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the 2.4 mm screw using a Phillips #00 screwdriver.
  11. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 11, 1 resimden 1.
    • Slide the solid state drive to the left and out of its port.
    • Be careful when removing the solid state drive as bending any of the pins may render it unusable.
  12. HP EliteBook x360 1030 G3 Keyboard Replacement, WWAN Card: adım 12, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement, WWAN Card: adım 12, 2 resimden 2.
    • Detach the small wires connected to the card by lifting the ends straight upward. The wires are held in place by friction and should pop right off.
    • These wires should be handled carefully since they're the mobile cell service/WWAN antennas.
    • Take note of which wire goes where, as mixing these cables will cause the mobile cell service/WWAN to stop working.
  13. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 13, 1 resimden 1.
    • Remove the 2.4 mm screw holding the card down using a Phillips #00 screwdriver.
  14. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 14, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 14, 2 resimden 2.
    • Carefully pull out the card by sliding it to the left.
  15. HP EliteBook x360 1030 G3 Keyboard Replacement, Motherboard: adım 15, 1 resimden 1.
    • Remove the single 5 mm screw holding the HDMI port cover in place using a Phillips #0 screwdriver.
  16. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 16, 1 resimden 1.
    • Lift and remove the HDMI port cover.
  17. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 17, 1 resimden 1.
    • Disconnect the red and blue display wires using an iFixit opening tool.
  18. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 18, 1 resimden 1.
    • Detach the display wire connector using a nylon spudger. Repeat on the other side.
  19. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 19, 1 resimden 1.
    • Flip up the five white wire clips and the single black clip using an iFixit opening tool.
    • Detach the wires connected to the motherboard.
    • Remove the two 5 mm screws that hold the motherboard in place with a Phillips #1 screwdriver.
  20. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 20, 1 resimden 1.
    • Push in the SD card slot.
  21. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 21, 1 resimden 1.
    • Remove the SD card slot.
  22. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 22, 1 resimden 1.
    • Carefully remove the motherboard from the device by sliding it away from the laptop hinge and lifting upwards. Pull the blue sticky foam off of the back of the motherboard.
  23. HP EliteBook x360 1030 G3 Keyboard Replacement, Keyboard: adım 23, 1 resimden 1.
    • Remove the six 5.7 mm hinge screws using a Phillips #0 screwdriver.
  24. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 24, 1 resimden 1.
    • Lift up the black ribbon wire that is attached to the back of the keyboard to reveal hidden screws.
  25. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 25, 1 resimden 1.
    • Lift up the black protective layer from the back of the keyboard to reveal more hidden screws.
  26. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 26, 1 resimden 1.
    • Remove fifty-seven 1.5 mm screws securing the keyboard assembly in place using a Phillips #0 screwdriver.
  27. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 27, 2 resimden 1. HP EliteBook x360 1030 G3 Keyboard Replacement: adım 27, 2 resimden 2.
    • Lift the keyboard up and remove from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Moses Cung
388 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley Summer 2023 IUPUI, Team 2-2, Harley Summer 2023 üyesi
IUPUI-HARLEY-SU23S2G2
3 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Sehr gute Anleitung.
Allerdings sind die 15 Minuten nicht realistisch.
Alleine die Demontage der 57 Schrauben dauert länger.
Zerlegen und wieder zusammenbauen dauert zwischen ein und zwei Stunden.
Dennis Stirner - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 106
Her zaman: 1,951
