Ana içeriğe geç
HP EliteBook x360 830 G7 Battery Replacement
Emily Kaplan
Emily Kaplan ve 6 diğer katkıda bulunanlar
En son June 24, 2024 tarihinde güncellendi
5 dakika
Kolay
This guide will help you remove the battery from your HP EliteBook x360 830 G7 laptop. If the battery of your HP EliteBook x360 830 G7 is draining fast recently, it is probably dying and needs to be replaced.
Batteries are important components of laptops, and without a functional battery your laptop might not perform in the desired manner. Batteries have a limited lifecycle, and after several charge cycles, they might start to drain quicker than usual. If this is happening with you, you might want to start by calibrating the battery. If the problem persists, you most likely need to replace the battery.
This guide will teach you how to replace your HP EliteBook x360 830 G7 battery safely and effectively. Make sure to power down your device before you start.
Neye ihtiyacın var
Parçalar
Aletler
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • JIS #1
  • Spudger
    Spudger
Daha fazlasını göster…
  1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: adım 1, 3 resimden 1. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: adım 1, 3 resimden 2. HP EliteBook x360 830 G7 Battery Replacement, Remove the backplate: adım 1, 3 resimden 3.
    • Turn the computer over so that the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7 Battery Replacement, Disconnect the bundled cable connector: adım 2, 1 resimden 1.
    • Use a nylon spudger to gently disconnect the battery's bundled cable connector from the motherboard.
    • This bundled cable connector has a tab on each side. Insert the spudger between these tabs and the motherboard's battery connector port and gently push the battery connector out and away from the connector.
  3. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: adım 3, 2 resimden 1. HP EliteBook x360 830 G7 Battery Replacement, Peel the copper foil tape: adım 3, 2 resimden 2.
    • Peel back both sides of the copper foil tape connected to the battery.
  4. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: adım 4, 2 resimden 1. HP EliteBook x360 830 G7 Battery Replacement, Remove the screws: adım 4, 2 resimden 2.
    • Use a JIS #1 screwdriver to remove the four 4 mm screws that secure the battery.
  5. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: adım 5, 3 resimden 1. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: adım 5, 3 resimden 2. HP EliteBook x360 830 G7 Battery Replacement, Remove the battery: adım 5, 3 resimden 3.
    • Remove the battery from the laptop.
Sonuç
Emily Kaplan
217 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 26
Son 30 gün: 67
Her zaman: 1,238
