Ana içeriğe geç
HP Elitebook 8460p Bluetooth Card Replacement
Garrett Anderson
Garrett Anderson ve 3 diğer katkıda bulunanlar
En son December 6, 2019 tarihinde güncellendi
10 dakika
Kolay
Use this guide to replace the Bluetooth card for the HP Elitebook 8460p if you are having problems with Bluetooth connectivity and have ruled out any problems with the computer operating system. Use this guide to also gain access to the wire connections to the Bluetooth chip to reconnect the wires.
Take care to ground yourself using an ESD strap to prevent electrostatic discharges from damaging the Bluetooth card further, or from damaging the motherboard.
  1. HP Elitebook 8460p Bluetooth Card Replacement, Battery: adım 1, 1 resimden 1.
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Bluetooth Card Replacement: adım 2, 1 resimden 1.
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Bluetooth Card Replacement, Back Panel: adım 3, 1 resimden 1.
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Bluetooth Card Replacement: adım 4, 1 resimden 1.
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: adım 5, 2 resimden 1. HP Elitebook 8460p Bluetooth Card Replacement, Bluetooth Card: adım 5, 2 resimden 2.
    • Attach an ESD strap to your wrist and to a ground.
    • Using a fingernail, grasp the small connector and separate the connector from the Bluetooth card.
  6. HP Elitebook 8460p Bluetooth Card Replacement: adım 6, 1 resimden 1.
    • Grasp the Bluetooth card and pull it straight out to the left.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 18
Son 7 gün: 32
Son 30 gün: 63
Her zaman: 5,590
