Ana içeriğe geç
HP Pavilion 14-bk061st Heat Sink Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: adım 1, 2 resimden 1. HP Pavilion 14-bk061st Heat Sink Replacement, Back Panel: adım 1, 2 resimden 2.
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Heat Sink Replacement: adım 2, 1 resimden 1.
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Heat Sink Replacement: adım 3, 1 resimden 1.
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: adım 4, 2 resimden 1. HP Pavilion 14-bk061st Heat Sink Replacement, Heat Sink: adım 4, 2 resimden 2.
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  5. HP Pavilion 14-bk061st Heat Sink Replacement: adım 5, 1 resimden 1.
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stefano Lo Re
382 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 362
