Ana içeriğe geç
HP Pavilion 14-cf0014dx Battery Replacement
Neye ihtiyacın var
  1. HP Pavilion 14-cf0014dx Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Battery Replacement: adım 2, 1 resimden 1.
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Battery Replacement: adım 4, 1 resimden 1.
    • Lift the battery up and out and remove it from the device.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Sam Cole
813 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 üyesi
UMASSD-SINCLAIRE-F21S2G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 28
Her zaman: 1,451
