Ana içeriğe geç
HP Pavilion 14-v062us Screen Replacement
Neye ihtiyacın var
    1. HP Pavilion 14-v062us Screen Replacement, Battery: adım 1, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Power laptop off and make sure it is not plugged into charger
      • Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Screen Replacement: adım 2, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 2, 2 resimden 2.
      • Lift the battery upwards and out from the laptop
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 14-v062us Screen Replacement, Keyboard: adım 3, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement, Keyboard: adım 3, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement, Keyboard: adım 3, 3 resimden 3.
      • Remove rectangular rubber tops with a spudger
      • Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
      • Remove plastic edge covering with the blue plastic opening tool.
      • Remove two 4.63 mm PH#1 screws located under plastic edge covering.
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Screen Replacement: adım 4, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 4, 2 resimden 2.
      • Use Phillips screwdriver #1
      • Remove all nine 7.09 mm PH#1 screw black screws including small rectangular cover.
      • Remove the three 7.14 mm PH#1 screws.
      • Remove the one 7.09 mm PH#1 screw that will be underneath the small rectangular cover
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 14-v062us Screen Replacement: adım 5, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 5, 2 resimden 2.
      • Remove disc tray
      • Locate screw within computer that is inside of where the disc tray was
      • Using a Phillips #1 screwdriver, unscrew the screw
      • Set laptop down and open laptop so the keyboard is facing you
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 14-v062us Screen Replacement: adım 6, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 6, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement: adım 6, 3 resimden 3.
      • Using a spudger or plastic opening tool, pry along siding of keyboard, where it connects to the rest of the laptop
      • Pry until you are able to lift entire face and keyboard
      • Only cables should be connecting it underneath
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 14-v062us Screen Replacement: adım 7, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 7, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement: adım 7, 3 resimden 3.
      • Disconnect/ unplug cables using plastic opening tool.
      • Separate the keyboard panel from the laptop with your hands.
      • Turn around the laptop and lay it flat.
      FixBot'a Sor
      Yorum Ekle
    6. HP Pavilion 14-v062us Screen Replacement: adım 8, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 8, 2 resimden 2.
      • Use a spudger to pry around the first layer of the silver panel until you are able to remove it
      • Only use a metal spudger as a last resort
      FixBot'a Sor
      Yorum Ekle
    7. HP Pavilion 14-v062us Screen Replacement: adım 9, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 9, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement: adım 9, 3 resimden 3.
      • Using a spudger tool, start prying around the second layer of the silver panel until you are able to remove it
      FixBot'a Sor
      Yorum Ekle
    1. HP Pavilion 14-v062us Screen Replacement, Screen: adım 10, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement, Screen: adım 10, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement, Screen: adım 10, 3 resimden 3.
      • Using the spudger, wedge tool in between screen and laptop
      • Only use a metal spudger as a last resort. A regular black nylon spudger or a plastic opening tool should be used whenever possible
      • Pry open screen with spudger and your hands
      FixBot'a Sor
      Yorum Ekle
    2. HP Pavilion 14-v062us Screen Replacement: adım 11, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 11, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement: adım 11, 3 resimden 3.
      • Remove the four 2.86 mm JIS#0 screws from each corner of the silver frame that is holding the digitizer.
      FixBot'a Sor
      Yorum Ekle
    3. HP Pavilion 14-v062us Screen Replacement: adım 12, 2 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 12, 2 resimden 2.
      • Locate the white and brown wiring that connects to the digitizer and the screen.
      • Cut through the clear part of tape attached to the brown latch and white wiring.
      • Disconnect the wiring, by lifting the brown latch with the blue plastic opening tool and pulling the white wire at the same time.
      • Lift off the digitizer. If you need to replace the digitizer stop here and replace this part.
      • If you need to replace the screen, then continue
      FixBot'a Sor
      Yorum Ekle
    4. HP Pavilion 14-v062us Screen Replacement: adım 13, 1 resimden 1.
      • Remove the four 5.66 mm PH#0 from under the keyboard near the hinges.
      FixBot'a Sor
      Yorum Ekle
    5. HP Pavilion 14-v062us Screen Replacement: adım 14, 3 resimden 1. HP Pavilion 14-v062us Screen Replacement: adım 14, 3 resimden 2. HP Pavilion 14-v062us Screen Replacement: adım 14, 3 resimden 3.
      • Wedge spudger in between screen and back of computer
      • Detach screen
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 1,892
