Ana içeriğe geç
HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
Efren Solis
Efren Solis ve 9 diğer katkıda bulunanlar
En son December 14, 2022 tarihinde güncellendi
15 dakika
Orta
Daha İyi Resimler Gerekli
This step-by-step guide will explain how to open and remove your HP Pavilion Notebook 15-ab293cl hard drive. After removing the hard drive, you can easily replace it.
The hard drive is the device in your computer that stores and retrieves your saved data. If you are running low on space, upgrading your hard drive will give you more space to work. If your hard drive fails, replacing your it will allow you to continue using your computer.
Neye ihtiyacın var
Tamir Setleri
Bu kitler, bu kılavuzu tamamlamak için gereken tüm parçaları ve araçları içerir.
Parçalar
Aletler
Daha fazlasını göster…
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 2, 3 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 2, 3 resimden 2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 3, 2 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 3, 2 resimden 2.
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 4, 3 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 4, 3 resimden 2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 5, 1 resimden 1.
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 6, 3 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 6, 3 resimden 2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 6, 3 resimden 3.
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 7, 3 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 7, 3 resimden 2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 7, 3 resimden 3.
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 8, 2 resimden 1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: adım 8, 2 resimden 2.
    • Once you release the white tab from the green board, remove the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Efren Solis
228 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team S1-G2, Luster Fall 2018 Gateway, Team S1-G2, Luster Fall 2018 üyesi
GCC-LUSTER-F18S1G2
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 23
Son 30 gün: 87
Her zaman: 2,801
