HP Pavilion dv5000 Keyboard Replacement
Giriş
1. adıma gitThis guide will show you how to remove the keyboard, in case you need to replace it.
Neye ihtiyacın var
Aletler
Lay the computer face-down on a flat surface. Orient the computer to match the image.
Locate the battery release switch, as indicated in the image by the red rectangle. Slide the switch from right to left, and remove the battery.
Remove the two 11.0mm screws at the corners on either side of the battery compartment.
Remove the three 6.0mm screws.
Remove the two 5.0mm screws.
Remove the 6.0mm screw in the middle of the battery compartment.
Carefully lift the trackpad-side edge of the keyboard to reveal the LED and keyboard cable connectors.
Detach the cable connectors from the computer by gripping each cable connector close to the computer contact point and pulling up gently.
When reassembling, you need to push the little tabs next to the connector up before connecting the cable.
6 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Hey is keyboard replacement same or very similiar procedure with hp dv8000?
Brilliant. This is the best tutorial out there. Many thanks indeed!!!!
