Ana içeriğe geç
HP ProBook 455 G7 Battery Replacement
Neye ihtiyacın var
  1. HP ProBook 455 G7 Battery Replacement, Lower Case: adım 1, 1 resimden 1.
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 455 G7 Battery Replacement: adım 2, 3 resimden 1. HP ProBook 455 G7 Battery Replacement: adım 2, 3 resimden 2. HP ProBook 455 G7 Battery Replacement: adım 2, 3 resimden 3.
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 455 G7 Battery Replacement, Battery: adım 3, 3 resimden 1. HP ProBook 455 G7 Battery Replacement, Battery: adım 3, 3 resimden 2. HP ProBook 455 G7 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andiany Reynoso
253 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-6, Botvin Fall 2025 UMass Dartmouth, Team 1-6, Botvin Fall 2025 üyesi
UMASSD-BOTVIN-F25S1G6
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 173
