Ana içeriğe geç
HP ProBook 640 G2 Battery Replacement
Neye ihtiyacın var
  1. HP ProBook 640 G2 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the laptop so the bottom is facing up.
    • Use a JIS J1 screwdriver to remove eight 6 mm screws from the bottom of the laptop case.
    • Use a Torx T9 screwdriver to remove the single 6 mm screw.
    FixBot'a Sor
    Yorum Ekle
  2. HP ProBook 640 G2 Battery Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to carefully pry the bottom case.
    • Insert the end of the opening tool into the seam between the bottom and top case and slide it around the perimeter to release the clips.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  3. HP ProBook 640 G2 Battery Replacement: adım 3, 3 resimden 1. HP ProBook 640 G2 Battery Replacement: adım 3, 3 resimden 2. HP ProBook 640 G2 Battery Replacement: adım 3, 3 resimden 3.
    • Use a JIS J1 screwdriver to remove the seven 6 mm screws securing the battery.
    • Lift the battery from the bottom edge and slide it out of the socket on the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Note - Be sure to dispose of your old battery responsibly! Check out iFixit's Guide on Recycling E-waste.
For optimal performance, calibrate your newly installed battery after completing this guide.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 17
Son 30 gün: 59
Her zaman: 366
