Ana içeriğe geç
HP Spectre 13 4003dx x360 Battery Replacement
Neye ihtiyacın var
  1. HP Spectre 13 4003dx x360 Battery Replacement, Battery: adım 1, 2 resimden 1. HP Spectre 13 4003dx x360 Battery Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    Satın Al
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Battery Replacement: adım 2, 2 resimden 1. HP Spectre 13 4003dx x360 Battery Replacement: adım 2, 2 resimden 2.
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Battery Replacement: adım 3, 2 resimden 1. HP Spectre 13 4003dx x360 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Battery Replacement: adım 4, 3 resimden 1. HP Spectre 13 4003dx x360 Battery Replacement: adım 4, 3 resimden 2. HP Spectre 13 4003dx x360 Battery Replacement: adım 4, 3 resimden 3.
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
Sonuç
For optimal performance, after completing this guide, calibrate your newly installed battery.
7 farklı kişi bu kılavuzu tamamladı.
Alie Antar
661 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S5G4
3 Üyeler
8 adet Kılavuz yazıldı
5 Yorum
I have five T4 screws that came out without issue and three that refuse to budge. Now I am trying to figure out how to remove those without damaging the laptop itself.
fxb - Yanıt
Thank you! iFixit repair kit made getting the screws out easy. Now have a renewed laptop ready with 6 plus hours of battery life.
Nicholas Steblay - Yanıt
Tutoriel parfait, excepté peut-être qu’un double-fil côté droit de la batterie doit être libéré avant de sortir la batterie.
Bravo et merci, ça m’a tout simplement permis de me dépanner seul.
FirstName LastName - Yanıt
The official HP Manual (http://h10032.www1.hp.com/ctg/Manual/c04...) mentions using Torx T5 to remove the bottom cover.
Gitesh Agarwal - Yanıt
Thanks! I will correct the step with the right screw size.
Arthur Shi -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 75
Son 30 gün: 232
Her zaman: 22,739
