Ana içeriğe geç
HTC Vive Eyepiece Midframe Replacement
Adam O'Camb
Adam O'Camb
En son March 20, 2022 tarihinde güncellendi
20 - 40 dakika
Orta
Use this guide to remove and replace the eyepiece midframe in an HTC Vive.
You'll need a narrow, long-shaft driver to reach some of the screws in this guide.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: adım 1, 3 resimden 1. HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: adım 1, 3 resimden 2. HTC Vive Eyepiece Midframe Replacement, Open the cable compartment: adım 1, 3 resimden 3.
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Eyepiece Midframe Replacement, Unplug the HDMI cable: adım 2, 2 resimden 1. HTC Vive Eyepiece Midframe Replacement, Unplug the HDMI cable: adım 2, 2 resimden 2.
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: adım 3, 3 resimden 1. HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: adım 3, 3 resimden 2. HTC Vive Eyepiece Midframe Replacement, Unplug the remaining cables: adım 3, 3 resimden 3.
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: adım 4, 3 resimden 1. HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: adım 4, 3 resimden 2. HTC Vive Eyepiece Midframe Replacement, Unscrew the outer shell: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  5. HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: adım 5, 3 resimden 1. HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: adım 5, 3 resimden 2. HTC Vive Eyepiece Midframe Replacement, Remove the outer shell: adım 5, 3 resimden 3.
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  6. HTC Vive Eyepiece Midframe Replacement: adım 6, 2 resimden 1. HTC Vive Eyepiece Midframe Replacement: adım 6, 2 resimden 2.
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  7. HTC Vive Eyepiece Midframe Replacement: adım 7, 2 resimden 1. HTC Vive Eyepiece Midframe Replacement: adım 7, 2 resimden 2.
    • Slide the right side of the outer shell to the right and off of the headset.
  8. HTC Vive Eyepiece Midframe Replacement: adım 8, 2 resimden 1. HTC Vive Eyepiece Midframe Replacement: adım 8, 2 resimden 2.
    • Repeat the last three steps for the left side of the outer shell and remove it.
  9. HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: adım 9, 3 resimden 1. HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: adım 9, 3 resimden 2. HTC Vive Eyepiece Midframe Replacement, Remove the eyepiece midframe: adım 9, 3 resimden 3.
    • Hinge the OLED and lens frames down and away from the focus knob end of the eyepiece midframe.
    • Once you've rotated the OLED and lens frame about 90 degrees, push them straight down, parallel to the face of the eyepiece midframe, to separate them from the midframe.
Sonuç
Adam O'Camb
209.899 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,042
