Ana içeriğe geç
HTC Vive Sensor Array Replacement
Neye ihtiyacın var
  1. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 1. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 2. HTC Vive Sensor Array Replacement, Open the cable compartment: adım 1, 3 resimden 3.
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: adım 2, 2 resimden 1. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: adım 2, 2 resimden 2.
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 1. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 2. HTC Vive Sensor Array Replacement, Unplug the remaining cables: adım 3, 3 resimden 3.
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 1. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: adım 4, 2 resimden 2.
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
    Helaas blijkt de T5 Torx schroevendraaier aan de schroeven van de bevestigingsbeugels geen grip te krijgen. Wat dan gedaan?
    Immanuel Van Meirhaeghe - Yanıt
    It was a T6 that fit perfectly in mine, T5 didn't cut it. Maybe it's a revision thing? Mine was an early model from 2016.
    Edit: Edited guide to say T6.
    Tim T - Yanıt
  5. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 1. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 2. HTC Vive Sensor Array Replacement, Remove the head strap mounts: adım 5, 3 resimden 3.
    • Remove both head strap mounts.
  6. HTC Vive Sensor Array Replacement, Remove the facerest: adım 6, 2 resimden 1. HTC Vive Sensor Array Replacement, Remove the facerest: adım 6, 2 resimden 2.
    • Slide the facerest straight away from the headset to remove it.
  7. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 1. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 2. HTC Vive Sensor Array Replacement, Unscrew the outer shell: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  8. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 1. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 2. HTC Vive Sensor Array Replacement, Remove the outer shell: adım 8, 3 resimden 3.
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  9. HTC Vive Sensor Array Replacement: adım 9, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 9, 2 resimden 2.
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  10. HTC Vive Sensor Array Replacement: adım 10, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 10, 2 resimden 2.
    • Slide the right side of the outer shell to the right and off of the headset.
  11. HTC Vive Sensor Array Replacement: adım 11, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 11, 2 resimden 2.
    • Repeat the last three steps for the left side of the outer shell and remove it.
  12. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 1. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 2. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: adım 12, 3 resimden 3.
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
    During this step, there should be a picture of the flip side showing 4 more Philips screws hidden deep inside the headset. Removing those additional 4 screws is critical to getting the headset opened and continuing to the next step.
    Jeff - Yanıt
  13. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 1. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 2. HTC Vive Sensor Array Replacement: adım 13, 3 resimden 3.
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
    This guide is grossly incomplete. Do NOT try to pull up the sensor array after taking these five screws off. There are 8 more screws that have to be removed, as well as 2 tabs that need to be pushed before the sensor array comes off.
    -Two screws on the bottom (by the camera) to each side. There are four screws here, but only the outermost two need to be taken off. See the two sensors on the bottom? The screws under the outside corner of each sensor are the ones you remove.
    -Two screws on the top, to the right and left of the cable opening.
    -Four screws on the back, to the left and right of the lenses. Turn the Vive around, the screws are deep inside four holes.
    -Finally, two tabs on the bottom by the camera. If you look closely you will see them!
    Dan OST - Yanıt
  14. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 1. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 2. HTC Vive Sensor Array Replacement: adım 14, 3 resimden 3.
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
    Sure, but how do you get a replacement array?
    TheGreatYogurt - Yanıt
    It starts with “lift the sensor array" but how am I supposed to do that? Its not just lifting off after unscrewing & disconnecting. What am I missing here?
    Daniel Connelly - Yanıt
  15. HTC Vive Sensor Array Replacement: adım 15, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 15, 2 resimden 2.
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
  16. HTC Vive Sensor Array Replacement: adım 16, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
  17. HTC Vive Sensor Array Replacement, Unscrew the sensor array: adım 17, 1 resimden 1.
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
  18. HTC Vive Sensor Array Replacement: adım 18, 1 resimden 1.
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
    On my 2016 headset, I had to remove two additional Phillips screws at the top (appear in picture) and two more at the bottom (which are not present in the headset pictured here, must be a different revision) before the sensor array comes off.
    Tim T - Yanıt
  19. HTC Vive Sensor Array Replacement: adım 19, 2 resimden 1. HTC Vive Sensor Array Replacement: adım 19, 2 resimden 2.
    Phillips #000 Screwdriver
    $5.49
    • You'll need a narrow, long-shaft driver to reach these screws.
  20. HTC Vive Sensor Array Replacement, Remove the sensor array: adım 20, 2 resimden 1. HTC Vive Sensor Array Replacement, Remove the sensor array: adım 20, 2 resimden 2.
    • Lift the sensor array away from the headset to remove it.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
210.197 İtibar
416 adet Kılavuz yazıldı
1Rehber Yorum
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
Holger - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 40
Her zaman: 3,246
