Ana içeriğe geç
Heel Tip Replacement
Stephanie Shipman
Stephanie Shipman ve 3 diğer katkıda bulunanlar
En son December 5, 2024 tarihinde güncellendi
15 dakika
Kolay
Are your heel tips worn down or missing? Walking on metal tips, or uneven worn down rubber tips can be extremely frustrating. With extensive wear, heel tips will naturally deteriorate. It is recommended that they are replaced before the inner tip begins to protrude. This is also important because having an unstable heel can lead to balancing issues.
If you or someone you know have worn down or missing heel tips, you can use this guide to learn how to simply replace your old heel tips with new tips. Why pay a shoe repair shop to replace heel tips, when you can do it yourself and save time and money.
  1. Heel Tip Replacement, Heel Tip: adım 1, 1 resimden 1.
    • Measure the size of your heel tips to know what size to purchase.
    • Most sizes are in the range of 8-13 mm. The variety packs are handy, especially if you have a few pairs to fix.
    • The size pictured in this fix is a 12mm heel tip on a size 9 heel.
  2. Heel Tip Replacement: adım 2, 1 resimden 1.
    • Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
    pincer pliers will also help to remove the metal part from the steel tube inside. Be careful not to pull the steel tube out. If the tip is quite worn down to the tube, you might need to drill out the heel pin
    Awethentique Pty Ltd - Yanıt
  3. Heel Tip Replacement: adım 3, 2 resimden 1. Heel Tip Replacement: adım 3, 2 resimden 2.
    • Carefully remove the heel tip with the pliers by twisting and pulling it out. Most can be turned counter clockwise to remove. Be careful not to pull only the rubber off.
  4. Heel Tip Replacement: adım 4, 2 resimden 1. Heel Tip Replacement: adım 4, 2 resimden 2.
    • Clean the newly exposed tip of any debris.
  5. Heel Tip Replacement: adım 5, 1 resimden 1.
    • Place the pin end of the new tip into the heels opening.
    If you find the following cases:
    Heel Pin too thick: Grind down the pin carefully to make them fit
    Heel Pin too thin: You can hammer the pin on an avil to slightly flatten it out so that they fit snugly and can be hammered in, or twist some copper wire together and insert with the heel tip to make it thicker so that you can hammer it in snugly
  6. Heel Tip Replacement: adım 6, 2 resimden 1. Heel Tip Replacement: adım 6, 2 resimden 2.
    • Gently tap the new tip in with the hammer. Careful not to damage the shoes material.
  7. Heel Tip Replacement: adım 7, 2 resimden 1. Heel Tip Replacement: adım 7, 2 resimden 2.
    • Adjust the tip with the pliers to align the heel tip.
    What can I do if the original pin hole is too big for the replacement heel pins?
    Mary - Yanıt
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Stephanie Shipman
533 İtibar
1 Kılavuz yazıldı
Ekip
2Kılavuz Yorumları
What if the replacement pins are too small for original pin hole in the heel?
Mary - Yanıt
I have just added a comment to help with this
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 24
Son 7 gün: 101
Son 30 gün: 432
Her zaman: 91,960
