Ana içeriğe geç
How to Assemble the iMac Cardboard Service Wedge
Craig Lloyd
Craig Lloyd ve başka bir katkıda bulunan
En son July 14, 2022 tarihinde güncellendi
1 - 2 dakika
Çok kolay
Follow this guide to assemble the iMac Cardboard Service Wedge, which ships unfolded and flat. Once assembled, this product is not designed to be unfolded.
Neye ihtiyacın var
  1. How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: adım 1, 3 resimden 1. How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: adım 1, 3 resimden 2. How to Assemble the iMac Cardboard Service Wedge, Fold the tabs: adım 1, 3 resimden 3.
    • With the blank side facing you, fold the two tabs inward at a 90-degree angle.
  2. How to Assemble the iMac Cardboard Service Wedge, Fold the outer side flaps: adım 2, 2 resimden 1. How to Assemble the iMac Cardboard Service Wedge, Fold the outer side flaps: adım 2, 2 resimden 2.
    • Fold the two outer side flaps inward at a 90-degree angle.
  3. How to Assemble the iMac Cardboard Service Wedge, Fold it in half: adım 3, 3 resimden 1. How to Assemble the iMac Cardboard Service Wedge, Fold it in half: adım 3, 3 resimden 2. How to Assemble the iMac Cardboard Service Wedge, Fold it in half: adım 3, 3 resimden 3.
    • Fold the two halves together, using the crease in the center as the folding point.
    • Overlap the two outer side flaps, making sure the flap with the two small tabs is on top.
  4. How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: adım 4, 3 resimden 1. How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: adım 4, 3 resimden 2. How to Assemble the iMac Cardboard Service Wedge, Insert the tabs into the slots: adım 4, 3 resimden 3.
    • Insert the two tabs into the slots along the fold.
    • Make sure the flared edges on either side of the tabs are inserted completely into the slots so that they lock in place and don't slide out.
  5. How to Assemble the iMac Cardboard Service Wedge, Place it under your iMac: adım 5, 2 resimden 1. How to Assemble the iMac Cardboard Service Wedge, Place it under your iMac: adım 5, 2 resimden 2.
    • Your iMac Cardboard Service Wedge is ready to go!
    • Insert the Service Wedge under the iMac's display to hold it in place while you perform repairs on your iMac.
    How and where does one get hold of this product?
    What are its dimensions? Is there a template?
    Thank you
    Michael Sheriff - Yanıt
Bitiş Çizgisi
45 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
39.002 İtibar
82 adet Kılavuz yazıldı
1Rehber Yorum
Nice explanation, however, the cardboard stand is available in the US and not here and so it the dual HD cable for the iMac Intel 27” (mid 2011).
No good posting a great helps tory if the parts are not sold in Australia.
Hank Doll - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 44
Son 30 gün: 238
Her zaman: 14,354
