Ana içeriğe geç
How to Fix A Stripped Screw Hole
Isaiah Valdez Mireles
Isaiah Valdez Mireles ve başka bir katkıda bulunan
En son December 27, 2022 tarihinde güncellendi
30 - 35 dakika
Kolay
Öne Çıkan Öğrenci Kılavuzu
A stripped screw hole occurs when the fibers around the hole deteriorate. It can be caused by too much weight on the screw, changes in the weather, and overscrewing. This guide will instruct readers on how to repair a stripped screw hole. The instructions are beginner friendly, and the estimated time to complete is 30-35 minutes.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. How to Fix A Stripped Screw Hole, How to Fix A Stripped Screw Hole: adım 1, 1 resimden 1.
    • Using the toothpick as a reference, measure the depth of the screw-hole and the number of toothpicks needed to fill the screw hole.
  2. How to Fix A Stripped Screw Hole: adım 2, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 2, 2 resimden 2.
    • Next, using the wood glue, cover the area of the toothpick(s) that will fill in the screw hole.
  3. How to Fix A Stripped Screw Hole: adım 3, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 3, 2 resimden 2.
    • Place the toothpicks into the screw hole.
  4. How to Fix A Stripped Screw Hole: adım 4, 1 resimden 1.
    • Now, break off the exposed segment of the toothpick(s).
  5. How to Fix A Stripped Screw Hole: adım 5, 1 resimden 1.
    • Clean off the excess and let the wood glue dry for up to 30 minutes.
    • Recommended wood glue drying time may vary by product.
  6. How to Fix A Stripped Screw Hole: adım 6, 2 resimden 1. How to Fix A Stripped Screw Hole: adım 6, 2 resimden 2.
    • Finally, using the screwdriver, screw the screw into the repaired screw hole.
Sonuç
Your screw should now hold secure.
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 1,813
