Ana içeriğe geç
How to Open and Clean a PlayStation 5
Neye ihtiyacın var
  1. How to Open and Clean a PlayStation 5, Remove the stand screw: adım 1, 1 resimden 1.
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Open and Clean a PlayStation 5, Remove the vertical stand: adım 2, 2 resimden 1. How to Open and Clean a PlayStation 5, Remove the vertical stand: adım 2, 2 resimden 2.
    • Lift straight up to remove the stand.
  3. How to Open and Clean a PlayStation 5, Store the stand screw: adım 3, 2 resimden 1. How to Open and Clean a PlayStation 5, Store the stand screw: adım 3, 2 resimden 2.
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Open and Clean a PlayStation 5, Cap the screw hole: adım 4, 3 resimden 1. How to Open and Clean a PlayStation 5, Cap the screw hole: adım 4, 3 resimden 2. How to Open and Clean a PlayStation 5, Cap the screw hole: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Open and Clean a PlayStation 5, Close the cubby: adım 5, 3 resimden 1. How to Open and Clean a PlayStation 5, Close the cubby: adım 5, 3 resimden 2. How to Open and Clean a PlayStation 5, Close the cubby: adım 5, 3 resimden 3.
    • Twist the stand counterclockwise to close the cubby.
  6. How to Open and Clean a PlayStation 5, Remove the horizontal stand: adım 6, 2 resimden 1. How to Open and Clean a PlayStation 5, Remove the horizontal stand: adım 6, 2 resimden 2.
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
  7. How to Open and Clean a PlayStation 5, Remove the right faceplate: adım 7, 3 resimden 1. How to Open and Clean a PlayStation 5, Remove the right faceplate: adım 7, 3 resimden 2. How to Open and Clean a PlayStation 5, Remove the right faceplate: adım 7, 3 resimden 3.
    • Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
    • Lift up the corner of the faceplate to unclip it from the case.
  8. How to Open and Clean a PlayStation 5: adım 8, 2 resimden 1. How to Open and Clean a PlayStation 5: adım 8, 2 resimden 2.
    • While lifting up the corner, slide the faceplate towards the bottom of the device.
    • Remove the right faceplate.
  9. How to Open and Clean a PlayStation 5, Pry up the grille: adım 9, 3 resimden 1. How to Open and Clean a PlayStation 5, Pry up the grille: adım 9, 3 resimden 2. How to Open and Clean a PlayStation 5, Pry up the grille: adım 9, 3 resimden 3.
    • Insert the flat end of a spudger underneath the grille and into the gap above the fan.
    • Lift up with the spudger to pry the grille away from the case.
  10. How to Open and Clean a PlayStation 5, Remove the grille: adım 10, 2 resimden 1. How to Open and Clean a PlayStation 5, Remove the grille: adım 10, 2 resimden 2.
    • Lift the grille away from the case to remove it.
  11. How to Open and Clean a PlayStation 5, Remove the fan shroud screws: adım 11, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
    • Two 23.3 mm-long screws
    • One 11.4 mm-long screw
    • One 31 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  12. How to Open and Clean a PlayStation 5, Remove the fan shroud: adım 12, 2 resimden 1. How to Open and Clean a PlayStation 5, Remove the fan shroud: adım 12, 2 resimden 2.
    • Lift the fan shroud straight up to remove it.
  13. How to Open and Clean a PlayStation 5, Remove the wire cover: adım 13, 3 resimden 1. How to Open and Clean a PlayStation 5, Remove the wire cover: adım 13, 3 resimden 2. How to Open and Clean a PlayStation 5, Remove the wire cover: adım 13, 3 resimden 3.
    • Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
    • Pry only on the wire cover, not on the fan wires themselves.
    • Use the spudger to peel up the wire cover until you can grip it with your fingers.
  14. How to Open and Clean a PlayStation 5: adım 14, 3 resimden 1. How to Open and Clean a PlayStation 5: adım 14, 3 resimden 2. How to Open and Clean a PlayStation 5: adım 14, 3 resimden 3.
    • Use your fingers to peel off the wire cover.
  15. How to Open and Clean a PlayStation 5, Disconnect the fan: adım 15, 2 resimden 1. How to Open and Clean a PlayStation 5, Disconnect the fan: adım 15, 2 resimden 2.
    • Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
    • Always pull cables by their connectors and not the wires themselves.
  16. How to Open and Clean a PlayStation 5, Remove the fan: adım 16, 3 resimden 1. How to Open and Clean a PlayStation 5, Remove the fan: adım 16, 3 resimden 2. How to Open and Clean a PlayStation 5, Remove the fan: adım 16, 3 resimden 3.
    • Lift the fan up and out of the case to remove it.
  17. How to Open and Clean a PlayStation 5, Clean the fan: adım 17, 1 resimden 1.
    Dust Blower
    $18.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water or isopropyl alcohol on a cotton swab to wipe them off.
  18. How to Open and Clean a PlayStation 5, Remove the left faceplate: adım 18, 3 resimden 1. How to Open and Clean a PlayStation 5, Remove the left faceplate: adım 18, 3 resimden 2. How to Open and Clean a PlayStation 5, Remove the left faceplate: adım 18, 3 resimden 3.
    • Lift up the corner of the faceplate with the PlayStation logo to unclip it from the case.
    • Remove the left faceplate.
  19. How to Open and Clean a PlayStation 5, Clean the faceplates: adım 19, 1 resimden 1.
    Microfiber Cleaning Cloths
    $3.99
    • Use a clean rag or microfiber cloth to wipe the insides of the faceplates clean.
  20. How to Open and Clean a PlayStation 5, Clean vents and hard-to-reach areas: adım 20, 2 resimden 1. How to Open and Clean a PlayStation 5, Clean vents and hard-to-reach areas: adım 20, 2 resimden 2.
    Anti-Static Brush
    $2.99
    • With both faceplates off, now's the time to clean everything underneath that's normally hidden.
    • Two dust ports underneath the left faceplate can catch dust over time. Use a narrow vacuum attachment to clean out the ports.
    • Depending on how dirty your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas and off of the rear vents.
    • Use a dust blower to blow any loose dust out of the console and a cloth to wipe the vents clean.
  21. How to Open and Clean a PlayStation 5, Clean the heatsink: adım 21, 1 resimden 1.
    • Use a dust blower, brush, and a cloth to clean the inside of the fan cavity while the fan's removed.
    • The PS5 draws air through the heatsink fins, and they may clog with dust and debris over time.
    • If you can see dust buildup in the heatsink, use a dust blower to blow it clean.
    • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
Sonuç
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
6 farklı kişi bu kılavuzu tamamladı.
Carsten Frauenheim
136.958 İtibar
371 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
1Rehber Yorum
How do i clean the lebron faceplate?
Hugh Johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 172
Son 7 gün: 1,163
Son 30 gün: 5,780
Her zaman: 32,772
