Ana içeriğe geç
How to Repair USB Fairy Lights
Neye ihtiyacın var
  1. How to Repair USB Fairy Lights, How to Repair USB Fairy Lights: adım 1, 1 resimden 1.
    • Identify the damaged part of the fairy lights and ensure they are disconnected from the USB with no current flowing.
  2. How to Repair USB Fairy Lights: adım 2, 1 resimden 1.
    • Use a wire cutter to remove the coating from the broken ends of the wire, stripping about 1 cm (approximately the length of your fingernail).
    • Utilizing scissors and/or knives is also acceptable to achieve this step.
  3. How to Repair USB Fairy Lights: adım 3, 1 resimden 1.
    • Ensure the naked wire is exposed and free from the coating, allowing you to work with the soldering iron without interference.
  4. How to Repair USB Fairy Lights: adım 4, 1 resimden 1.
    • Use a nail file or sandpaper to sand the ends of the wire to remove impurities, then twist each end of the wire.
  5. How to Repair USB Fairy Lights: adım 5, 1 resimden 1.
    • Preheat the soldering iron to 300 degrees Celsius.
    • The soldering iron will be very hot; make sure your workspace is clear of clutter.
    • Usage of safety goggles is highly recommended to protect your eyes from the resulting fumes.
  6. How to Repair USB Fairy Lights: adım 6, 2 resimden 1. How to Repair USB Fairy Lights: adım 6, 2 resimden 2.
    • Bring the soldering wire close to the broken ends and start melting it using the iron.
    • Continue the process until the solder connects them securely.
  7. How to Repair USB Fairy Lights: adım 7, 1 resimden 1.
    • Turn on the fairy lights to see if they glow.
Sonuç
By following these steps, you should be able to repair your fairy lights and enjoy their glow once again.
Maher Kazi
145 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 19
Son 30 gün: 44
Her zaman: 356
