Ana içeriğe geç
How to Replace a G-Shock GA201-1A Battery
Neye ihtiyacın var
  1. How to Replace a G-Shock GA201-1A Battery, Battery: adım 1, 3 resimden 1. How to Replace a G-Shock GA201-1A Battery, Battery: adım 1, 3 resimden 2. How to Replace a G-Shock GA201-1A Battery, Battery: adım 1, 3 resimden 3.
    • Remove back cover by removing the four 6.2 mm Phillips #0 screws with the screwdriver.
    • Be careful not to lose the screws.
  2. How to Replace a G-Shock GA201-1A Battery: adım 2, 1 resimden 1.
    • Use the tweezers to remove the rubber gasket by lifting it.
  3. How to Replace a G-Shock GA201-1A Battery: adım 3, 2 resimden 1. How to Replace a G-Shock GA201-1A Battery: adım 3, 2 resimden 2.
    • Lift the white plastic covering with a pair of tweezers.
    • Be delicate; if too much force is applied, the watch's interior can pop out.
  4. How to Replace a G-Shock GA201-1A Battery: adım 4, 1 resimden 1.
    • Peel off the protective sticker from the surface of the old battery.
  5. How to Replace a G-Shock GA201-1A Battery: adım 5, 1 resimden 1.
    • Use tweezers to bend the metal guide away from the old battery.
  6. How to Replace a G-Shock GA201-1A Battery: adım 6, 1 resimden 1.
    • Remove the old battery from the guide with tweezers.
  7. How to Replace a G-Shock GA201-1A Battery: adım 7, 2 resimden 1. How to Replace a G-Shock GA201-1A Battery: adım 7, 2 resimden 2.
    • Slide the new battery into the frame and bend the metal guide onto the battery.
  8. How to Replace a G-Shock GA201-1A Battery: adım 8, 2 resimden 1. How to Replace a G-Shock GA201-1A Battery: adım 8, 2 resimden 2.
    • Reset the proper time and date using the top-left "adjust" button.
    • For further instructions, consult your G-Shock GA-201 User Manual.
Sonuç
To reassemble your watch, follow these instructions in reverse order.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Cordell Johnson
157 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 120
Son 30 gün: 510
Her zaman: 18,661
