Ana içeriğe geç
How to Replace a Google Pixel 2 Screen
Neye ihtiyacın var
  1. How to Replace a Google Pixel 2 Screen, Opening Procedure: adım 1, 2 resimden 1. How to Replace a Google Pixel 2 Screen, Opening Procedure: adım 1, 2 resimden 2.
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    FixBot'a Sor
    Yorum Ekle
  2. How to Replace a Google Pixel 2 Screen: adım 2, 3 resimden 1. How to Replace a Google Pixel 2 Screen: adım 2, 3 resimden 2. How to Replace a Google Pixel 2 Screen: adım 2, 3 resimden 3.
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • Do not insert the pick deeper than 1.5 mm, or you risk damaging the OLED panel.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
    FixBot'a Sor
    Yorum Ekle
  3. How to Replace a Google Pixel 2 Screen: adım 3, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 3, 2 resimden 2.
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 9 mm into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel it can damage the display.
    • Only make very shallow cuts in the upper left corner, prying deeply can damage the front-facing camera.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
    FixBot'a Sor
    Yorum Ekle
  4. How to Replace a Google Pixel 2 Screen: adım 4, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 4, 2 resimden 2.
    • In the following steps, use the flat of the opening pick, rather than a corner, to cut here. This will help prevent inserting the pick too deeply.
    • Slide the opening pick up the right side of the phone to separate the display adhesive.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
    FixBot'a Sor
    Yorum Ekle
  5. How to Replace a Google Pixel 2 Screen: adım 5, 3 resimden 1. How to Replace a Google Pixel 2 Screen: adım 5, 3 resimden 2. How to Replace a Google Pixel 2 Screen: adım 5, 3 resimden 3.
    • Slide the opening pick around the upper-right corner and along the top edge of the phone.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    FixBot'a Sor
    Yorum Ekle
  6. How to Replace a Google Pixel 2 Screen: adım 6, 3 resimden 1. How to Replace a Google Pixel 2 Screen: adım 6, 3 resimden 2. How to Replace a Google Pixel 2 Screen: adım 6, 3 resimden 3.
    • Slide the pick around the upper-left corner of the phone and down the left edge of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. How to Replace a Google Pixel 2 Screen: adım 7, 3 resimden 1. How to Replace a Google Pixel 2 Screen: adım 7, 3 resimden 2. How to Replace a Google Pixel 2 Screen: adım 7, 3 resimden 3.
    • Slide the pick around the bottom-left corner and along the bottom of the phone. Keep pick at a slight angle away from the screen to avoid damage to the OLED corners.
    • Take extra care not to insert the opening pick more than 9 mm to avoid damaging the OLED panel.
    FixBot'a Sor
    Yorum Ekle
  8. How to Replace a Google Pixel 2 Screen: adım 8, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 8, 2 resimden 2.
    • Reinsert the pick at the top edge of the phone and gently pry up the display.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive. The adhesive near the upper speaker is thicker than other places.
    • Don't try to fully separate the display yet, as a fragile ribbon cable still connects it to the phone's motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. How to Replace a Google Pixel 2 Screen: adım 9, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Carefully lay the display down on top of the rear case as shown, making sure not to crease or tear the display ribbon cable.
    • Remove the two 4.0 mm T5 Torx screws securing the display cable bracket.
    FixBot'a Sor
    Yorum Ekle
  10. How to Replace a Google Pixel 2 Screen: adım 10, 1 resimden 1.
    • Remove the display cable bracket.
    FixBot'a Sor
    Yorum Ekle
  11. How to Replace a Google Pixel 2 Screen: adım 11, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 11, 2 resimden 2.
    • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
    • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
    • During reassembly, pause here and replace the adhesive around the edges of the display.
    FixBot'a Sor
    Yorum Ekle
  12. How to Replace a Google Pixel 2 Screen, Screen: adım 12, 2 resimden 1. How to Replace a Google Pixel 2 Screen, Screen: adım 12, 2 resimden 2.
    • If your replacement display did not come with pre-installed speaker grilles or a front-facing camera bracket, carefully remove these parts from your old display. Follow the rest of the guide to install them on a new display.
    • To remove the camera bracket, apply heat, then use a thin metal blade to pry the bracket away from the old screen.
    • There are two layers that make up the speaker grille—the metal mesh grille, and a layer of thin fabric mesh behind it. Use tweezers to peel both layers off of the old screen together. Do your best to not separate those layers at all.
    • Make sure to install the grilles and gasket before applying display adhesive.
    • Cut two corners of a pre-cut adhesive card so that each side is no more than 12 mm (0.5 inches) long, or cut four 12 mm (0.5 inches) strips of double-sided adhesive.
    • The adhesive strips should be no wider than 1 mm.
    • Apply the adhesive strips to the edges of the flat side of the front-facing camera bracket. When you're done, there should be adhesive on all four edges of the camera bracket.
    • Gently press the adhesive into place using your finger or a spudger.
    FixBot'a Sor
    Yorum Ekle
  13. How to Replace a Google Pixel 2 Screen: adım 13, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 13, 2 resimden 2.
    • Place the camera bracket into its slot surrounding the front-facing camera.
    • Make sure the rounded corner of the bracket faces the upper left corner of the phone. If the bracket does not sit flush with the camera, it is not properly seated.
    • Peel the white backing off of the adhesive strips.
    FixBot'a Sor
    Yorum Ekle
  14. How to Replace a Google Pixel 2 Screen: adım 14, 1 resimden 1.
    • Use your finger or the flat edge of a spudger to reconnect the new screen's display cable connector.
    FixBot'a Sor
    Yorum Ekle
  15. How to Replace a Google Pixel 2 Screen: adım 15, 2 resimden 1. How to Replace a Google Pixel 2 Screen: adım 15, 2 resimden 2.
    • In this step, you will temporarily install the new screen in order to properly align it with the front-facing camera bracket while adhering the bracket to the screen.
    • Make sure there is no adhesive anywhere on the screen before attempting this step. You should not seal the phone closed yet.
    • Very carefully align the lower edge of your new display with the lower edge of the phone case.
    • Set the lower edge of the screen in the case, and slowly hinge it down toward the phone case, being careful to keep it properly aligned with the case.
    • Set the screen down in the case and press down on the front-facing camera hole to ensure that the bracket is adhered to the screen.
    • Lift the screen up and away from the phone case and check that the camera bracket is adhered to the screen.
    • Disconnect the display cable.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    FixBot'a Sor
    Yorum Ekle
  16. How to Replace a Google Pixel 2 Screen: adım 16, 3 resimden 1. How to Replace a Google Pixel 2 Screen: adım 16, 3 resimden 2. How to Replace a Google Pixel 2 Screen: adım 16, 3 resimden 3.
    • Cut a strip of 1 mm wide double-sided tape to be about 3 cm long (1.25 inches).
    • Lay the adhesive strip along the upper edge of the earpiece speaker slot in your new display so that it's centered over the slot and touching the upper edge.
    • The adhesive strip needs to be as close as possible to the edge of the slot without overlapping.
    • Gently press the adhesive strip into place on the display with your finger or a spudger.
    • Repeat this step to apply a second, identical adhesive strip along the bottom edge of the speaker slot.
    • Peel the white backing away from both adhesive strips.
    FixBot'a Sor
    Yorum Ekle
  17. How to Replace a Google Pixel 2 Screen: adım 17, 1 resimden 1.
    • Lightly set the speaker grille into its slot so that the curved grille sits in the slot and the flat side faces away from the screen.
    • Before pushing the grille down against the adhesive, make sure it is centered and properly seated in the slot.
    FixBot'a Sor
    Yorum Ekle
  18. How to Replace a Google Pixel 2 Screen: adım 18, 1 resimden 1.
    • Use the flat end of a spudger or your finger to push the edges of the speaker grille down against the adhesive strips.
    • Repeat the previous two steps to install the lower speaker grille.
    FixBot'a Sor
    Yorum Ekle
Sonuç
51 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
223.902 İtibar
416 adet Kılavuz yazıldı
21Kılavuz Yorumları
I removed my screen to change the battery but unfortunately I wasn’t careful enough and nicked the display on one of the corners resulting in a dead screen now.
I can replace the screen np, but I was wondering, I should be able to still connect my phone to my PC to check it is still working right? Because I have it connected now but there seems to be no power at all and my phone isn’t connecting to my PC to do a full backup. I have double checked all connections and held the power button in to try start it up or will it not start up if the screen is broken?
Leon Cope - Yanıt Paylaş
Have you gotten any further? I was doing a battery replacement and while removing the screen it cracked. Since I didn’t have a spare screen, I reassembled the phone with the cracked screen and saw some flashes of light but was dark. Upon attaching a replacement screen I get nothing on screen but can feel the vibration of the phone restarting. Tried a second replacement screen but no different.
Erik Karlin - Yanıt Paylaş
I needed to back up my files and pictures from my Pixel 2 to my PC with a dead screen just yesterday. I used the “squeeze” feature and asked the Google assistant to “turn on talkback.” This allows you to blindly navigate the screen (providing the touch functions still work). You can then use this feature combined with the Google assistant and fingerprint reader to open the navigation bar and change the PC connection from “charge only” to PTP. This will allow you to transfer your files. Hope this helps.
Sarah J. - Yanıt Paylaş
I recommend using a playing card instead of the plastic guitar pick to cut the adhesive once you get the side pried up a bit. It took just a moment for my hand to slip and the pick went too far in and chipped the corner of the OLED display. I also was trying to avoid using heat, but using even just a little of the low setting on my Harbor Freight heat gun really helped soften the adhesive up.
Chase Nachtmann - Yanıt Paylaş
This sounds like a great idea! I just put a pack of old playing cards in my repair kit. I destroyed my OLED display with a pick too. Hopefully next time I remember to use the playing cards and don’t mess this up.
Gabriel Staples - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 34
Son 30 gün: 148
Her zaman: 73,059
