Giriş
Sometimes your gear picks up stubborn grime: think grease, sunscreen, or mystery stains from the trail. This guide shows you how to spot clean using simple tools like dish soap, rubbing alcohol, and an adhesive eraser to tackle a variety of messes. Whether you're cleaning a jacket or a pack, these targeted techniques help refresh your gear and keep it looking sharp and performing well.
Related Tutorials
Neye ihtiyacın var
Mix a small amount of dish soap with warm water. Use a soft brush or dish towel to gently scrub the stain. Then, throw the item in the washing machine and launder according to the tag instructions.
Scrub the dirty area with a mixture of warm water and dish soap. Use a soft brush or dish towel, especially on technical fabrics like ripstop. Then, toss the item into the washing machine and launder it according to the tag instructions.
Soak a cotton ball in rubbing alcohol and gently wipe the stain. If you see the stain transfer onto the cotton ball, that means it's working.
Hold the adhesive eraser in one hand and use the other hand to create tension on the fabric. Rub the residue with the corner of the eraser to peel it away.
