Ana içeriğe geç
How to Use Suction Tape
  1. How to Use Suction Tape, Choose the tape: adım 1, 2 resimden 1. How to Use Suction Tape, Choose the tape: adım 1, 2 resimden 2.
    • If you want to secure one side of your two-panel device, skip to this step.
    • If you to buffer a difficult surface on your device, move to the next step.
  2. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 1. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 2. How to Use Suction Tape, Measure the tape: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • Measure the length of tape you want and mark it with a pen. Consider the following:
    • You need enough tape for the Anti-Clamp's suction cups. Don't leave gaps, or the cups won't stick.
    • Don't use too much tape so it folds over your phone's edges. This may interfere with the opening procedure.
  3. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 1. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 2. How to Use Suction Tape, Cut the tape: adım 3, 3 resimden 3.
    • Use scissors to cut the tape to the desired length.
    • Repeat the measuring and cutting procedure for each piece of tape required.
  4. How to Use Suction Tape, Peel the tape: adım 4, 2 resimden 1. How to Use Suction Tape, Peel the tape: adım 4, 2 resimden 2.
    • Peel the tape off its plastic liner.
  5. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 1. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 2. How to Use Suction Tape, Apply the tape: adım 5, 3 resimden 3.
    • Apply the tape to the panel of your device where you'll attach the Anti-Clamp.
  6. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 1. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 2. How to Use Suction Tape, Secure the tape: adım 6, 3 resimden 3.
    • Use the flat end of a spudger, or your finger, to completely secure the tape to your device.
    • Use a spudger to press out any large bubbles.
  7. How to Use Suction Tape, Open the device: adım 7, 2 resimden 1. How to Use Suction Tape, Open the device: adım 7, 2 resimden 2.
    • Repeat the tape measuring, cutting, and applying process for the opposite side of your device.
    • You're now ready to open your device!
    • Follow this guide for general instructions on how to use the Anti-Clamp.
  8. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 1. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 2. How to Use Suction Tape, Measure the tape: adım 8, 3 resimden 3.
    • The remaining steps show how to secure one side of your two-panel device.
    • Choose which panel of the device you don't want to open, and the following steps will show how to secure it.
    • In this example, we want to open the screen, so we'll secure the blue back cover.
    • You need to leave room for the Anti-Clamp's suction cups—don't place tape under them, or they won't stick.
    • Use enough tape to ensure a good hold on the panel you don't want to open.
    • Don't cover the power button with tape, or you might accidentally turn on the device.
  9. How to Use Suction Tape, Peel the tape: adım 9, 2 resimden 1. How to Use Suction Tape, Peel the tape: adım 9, 2 resimden 2.
  10. How to Use Suction Tape, Cut the tape: adım 10, 2 resimden 1. How to Use Suction Tape, Cut the tape: adım 10, 2 resimden 2.
  11. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 1. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 2. How to Use Suction Tape, Apply the tape: adım 11, 3 resimden 3.
    • Apply the tape to the edges of your device nearest to where you'll attach the Anti-Clamp.
    • Don't fold the tape over the panel you want to open, as this might hinder the opening procedure.
  12. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 1. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 2. How to Use Suction Tape, Fold the tape: adım 12, 3 resimden 3.
    • Fold the tape onto the panel you don't want to open.
    • Use your fingers to press down the tape and firmly secure it to your device.
  13. How to Use Suction Tape, Open the device: adım 13, 2 resimden 1. How to Use Suction Tape, Open the device: adım 13, 2 resimden 2.
Sonuç
For other general electronics skills guides, click here.
5 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
164.208 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
120 Üyeler
19.665 adet Kılavuz yazıldı
3Kılavuz Yorumları
Does anybody know the brand/type of tape? Searching for "suction tape" online leads to a different product.
Arturo - Yanıt
I suggest "carpet tape", used to join carpet sections together and often used for temporary joins in wood and metal working setups; or maybe Gorilla brand gaffer tape which is very grippy and has lots of reinforceing fiber strands for low stretch, (useing it now to hold the hinges of a laptop together till I get it fixed properly). Both can be found in most hardware/home care stores in USA. Cleanup of adhesive residue maybe a pain, requireing "goo gone" or WD-40 followed by alcohol wipes.
Kevin Smith - Yanıt
I would like to check the material of this product. Anyone can help me?
Nguyễn Thị Vân Anh - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 61
Son 30 gün: 341
Her zaman: 7,009
