Ana içeriğe geç
How to fix Mobee Magic Mouse disconnection issues
Peter Barnett
Peter Barnett ve 3 diğer katkıda bulunanlar
En son October 18, 2023 tarihinde güncellendi
Tahmin yok
Çok kolay
Topluluk-Katkılı Kılavuz
Giriş
I came here looking for a solution to my intermittent connection problems on my Mobee Magic Mouse - Apple iMac. I could not find anything, but I found this YouTube guide which has solved the problem.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
Video talimatları
Bitiş Çizgisi
30 farklı kişi bu kılavuzu tamamladı.
Peter Barnett
744 İtibar
1 Kılavuz yazıldı
Ekip
Dragon Upstream Consulting Limited Dragon Upstream Consulting Limited üyesi
Business
1 Üye
4 adet Kılavuz yazıldı
5Kılavuz Yorumları
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Yanıt
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Yanıt
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Yanıt
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Yanıt
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 33
Son 30 gün: 298
Her zaman: 39,429
