Ana içeriğe geç
How to open the SteelSeries Nimbus+ Controller
Neye ihtiyacın var
  1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: adım 1, 2 resimden 1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: adım 1, 2 resimden 2.
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
  2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: adım 2, 1 resimden 1.
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
  3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: adım 3, 1 resimden 1.
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
  4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: adım 4, 2 resimden 1. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: adım 4, 2 resimden 2.
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
  5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: adım 5, 2 resimden 1. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: adım 5, 2 resimden 2.
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
  6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: adım 6, 2 resimden 1. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: adım 6, 2 resimden 2.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
  7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: adım 7, 2 resimden 1. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: adım 7, 2 resimden 2.
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
  8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: adım 8, 3 resimden 1. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: adım 8, 3 resimden 2. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: adım 8, 3 resimden 3.
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
  9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: adım 9, 3 resimden 1. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: adım 9, 3 resimden 2. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
  10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: adım 10, 1 resimden 1.
    • Remove the back cover assembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adriana Zwink
62.406 İtibar
167 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.735 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 39
Her zaman: 1,823
