Ana içeriğe geç
Huawei Mate 10 Battery Replacement
Neye ihtiyacın var
    1. Huawei Mate 10 Battery Replacement, Remove the back cover: adım 1, 3 resimden 1. Huawei Mate 10 Battery Replacement, Remove the back cover: adım 1, 3 resimden 2. Huawei Mate 10 Battery Replacement, Remove the back cover: adım 1, 3 resimden 3.
      • Heat an iOpener and apply it to the bottom edge of the phone for two minutes. Re-heat the iOpener as needed.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone.
      • While you wait, note the location of the adhesive holding the back cover in place.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Mate 10 Battery Replacement: adım 2, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 2, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 2, 3 resimden 3.
      • Place a suction cup near the bottom edge of the back cover, on the right side (opposite the speaker grille) of the USB-C charging port, above the microphone hole.
      • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. If all else fails, you can superglue the suction cup to the back cover.
      • Pull on the suction cup with strong, steady force to create a gap.
      • Due to the adhesive's strength, this is very difficult and may take multiple attempts. If you can't create a gap, re-apply heat and try again.
      • Insert the point of an opening pick into the gap.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei Mate 10 Battery Replacement: adım 3, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 3, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 3, 3 resimden 3.
      • Slide the pick along the bottom edge and around the bottom-left corner, slicing through the adhesive.
      • If the adhesive feels tacky and difficult to slice, re-apply heat to the edge and try again.
      • Leave an opening pick in the seam to prevent the edge from re-sealing.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei Mate 10 Battery Replacement: adım 4, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 4, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 4, 3 resimden 3.
      • Apply a heated iOpener to the left edge of the phone.
      • Use an opening pick to slice through the adhesive on the left edge of the phone.
      • The adhesive is very thick in some areas. Sustained exposure to heat will help weaken the stubborn adhesive. Take your time, and apply heat liberally.
      FixBot'a Sor
      Yorum Ekle
    5. Huawei Mate 10 Battery Replacement: adım 5, 2 resimden 1. Huawei Mate 10 Battery Replacement: adım 5, 2 resimden 2.
      • Continue heating and slicing through the remaining edges, leaving opening picks in the seams to prevent the adhesive from re-sealing.
      FixBot'a Sor
      Yorum Ekle
    6. Huawei Mate 10 Battery Replacement: adım 6, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 6, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 6, 3 resimden 3.
      • After you cut through the adhesive around the entire perimeter of the back cover, begin to lift it away from the phone.
      • Use an opening pick to slice any remaining adhesive.
      • Remove the back cover.
      • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
      FixBot'a Sor
      Yorum Ekle
    7. Huawei Mate 10 Battery Replacement, Prep the phone for a new back cover: adım 7, 2 resimden 1. Huawei Mate 10 Battery Replacement, Prep the phone for a new back cover: adım 7, 2 resimden 2.
      • Before you install a replacement back cover, be sure to remove all traces of perimeter adhesive from the phone frame.
      • If you are re-using the back cover, carefully remove all traces of adhesive from the back cover.
      • The glass back cover is fragile and prone to cracking. Don't apply uneven pressure to the back cover as you clean.
      • You may pull up chunks of the cover's color coating as you remove the adhesive. To reduce the chances of this occurring, apply heat or high concentration isopropyl alcohol to the adhesive to weaken it.
      FixBot'a Sor
      Yorum Ekle
    8. Huawei Mate 10 Battery Replacement: adım 8, 2 resimden 1. Huawei Mate 10 Battery Replacement: adım 8, 2 resimden 2.
      • If your replacement back cover did not come with a flash diffuser or camera bezel, you will need to transfer them from your old cover to the new one.
      • Apply a heated iOpener directly over the bezels for a minute.
      • Use an opening pick to slice around the flash diffuser to loosen the adhesive.
      • The flash diffuser is made of plastic and cracks easily. Be sure to slice around the flash completely before you pry it off.
      • Use an opening tool to pry up and remove the camera bezel.
      • Transfer the parts to your replacement cover.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei Mate 10 Battery Replacement, Remove the plastic bracket: adım 9, 2 resimden 1. Huawei Mate 10 Battery Replacement, Remove the plastic bracket: adım 9, 2 resimden 2.
      • The next two steps show how to remove the heat dissipation layer, along with its plastic bracket.
      • Remove the eight 3.4 mm long Phillips screws securing the plastic bracket.
      • One screw lies beneath a white sticker. Remove the sticker.
      • Insert the point of a spudger underneath the right edge of the plastic bracket and pry up slightly to loosen the shield.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Mate 10 Battery Replacement: adım 10, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 10, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 10, 3 resimden 3.
      • Grasp the the lower edge of the plastic bracket with your fingers and lift the edge up slightly.
      • Pull the plastic bracket away from the top edge of the phone.
      • Slowly peel the black heat dissipation layer away from the phone. It is held in place with small patches of adhesive.
      • Remove the plastic bracket along with the heat dissipation layer.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei Mate 10 Battery Replacement, Disconnect the battery: adım 11, 2 resimden 1. Huawei Mate 10 Battery Replacement, Disconnect the battery: adım 11, 2 resimden 2.
      • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei Mate 10 Battery Replacement, Disconnect the interconnect cable: adım 12, 2 resimden 1. Huawei Mate 10 Battery Replacement, Disconnect the interconnect cable: adım 12, 2 resimden 2.
      • Use the point of a spudger to pry up and disconnect the wide interconnect flex cable from its motherboard socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      FixBot'a Sor
      Yorum Ekle
    5. Huawei Mate 10 Battery Replacement: adım 13, 2 resimden 1. Huawei Mate 10 Battery Replacement: adım 13, 2 resimden 2.
      • Use the point of a spudger to pry up and disconnect the fingerprint extension cable from its motherboard socket.
      FixBot'a Sor
      Yorum Ekle
    1. Huawei Mate 10 Battery Replacement, Disconnect the button connector: adım 14, 1 resimden 1.
      • Use the point of a spudger to pry up and disconnect the button connector from its motherboard socket.
      FixBot'a Sor
      Yorum Ekle
    2. Huawei Mate 10 Battery Replacement, Remove the glued-in battery: adım 15, 2 resimden 1. Huawei Mate 10 Battery Replacement, Remove the glued-in battery: adım 15, 2 resimden 2.
      • The battery is held in place by very strong adhesive.
      • Apply a heated iOpener to the left side of the phone screen for a minute.
      • While you wait, note where the U-shaped adhesive resides on the phone frame.
      FixBot'a Sor
      Yorum Ekle
    3. Huawei Mate 10 Battery Replacement: adım 16, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 16, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 16, 3 resimden 3.
      • Insert an opening pick in the notch on the phone's right edge.
      • Slowly but firmly push the pick underneath the battery, to loosen it from the frame.
      • If you are having trouble getting the pick under the battery, you can apply some high concentration isopropyl alcohol to the seam. Give the alcohol a minute to penetrate and soften the adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. Huawei Mate 10 Battery Replacement: adım 17, 2 resimden 1. Huawei Mate 10 Battery Replacement: adım 17, 2 resimden 2.
      • Slowly insert an opening pick in the top edge of the battery, towards the right edge.
      • Twist slightly to help loosen the battery.
      FixBot'a Sor
      Yorum Ekle
    5. Huawei Mate 10 Battery Replacement: adım 18, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 18, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 18, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Insert a plastic card under the battery's right edge.
      • Push the card inwards to loosen the battery from the frame.
      • If you're having a hard time loosening the battery, you can apply more isopropyl alcohol, or try to soften the adhesive with more heat.
      • Try not to deform the battery as you pry.
      FixBot'a Sor
      Yorum Ekle
    6. Huawei Mate 10 Battery Replacement: adım 19, 3 resimden 1. Huawei Mate 10 Battery Replacement: adım 19, 3 resimden 2. Huawei Mate 10 Battery Replacement: adım 19, 3 resimden 3.
      • Once the battery is sufficiently loosened from the frame, slowly lift it out.
      • Remove the battery.
      • To install a replacement battery:
      • Apply new adhesive to the phone frame.
      • Gently lay the battery pack in the phone.
      • Temporarily reconnect the battery to the motherboard to ensure that the battery is properly aligned.
      • Once the battery is aligned, press it firmly in place with your fingers. Disconnect the battery from the motherboard, and resume re-assembly.
      • For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mate 10 Answers community for help.
7 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
344.461 İtibar
915 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
38.654 adet Kılavuz yazıldı
6Kılavuz Yorumları
Excellent Guide!!! Very clear and detailed.. I replaced the battery on my Mate 10 in just 30 min without any problems.. Thank you!!!
Fernando Sancez - Yanıt Paylaş
Fantastic guide, Thanks!
Daniel Cocker - Yanıt Paylaş
Quest è il Mate 10 PRO, Aggiungete Pro!
Ed Evitiamo Confusione.
Just Step - Yanıt Paylaş
Buongiorno! Infatti questa guida è stata scritta per lo Huawei Mate 10. Se guardi bene questa foto, vedi il numero di modello ALP-L29 che corrisponde al Mate 10. Invece, siccome i due telefoni son molto simili, puoi seguire le stesse istruzioni per ripararli. Ma non devi! Ci sono qui le guide per il Mate 10 Pro.
Claire Miesch - Yanıt Paylaş
Muchas gracias, excelente información me ayudó muchísimo.
Rafa Sanchez - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 43
Son 30 gün: 130
Her zaman: 15,133
