Ana içeriğe geç
Huawei P10 Display Assembly with Frame Replacement
Neye ihtiyacın var
  1. Huawei P10 Display Assembly with Frame Replacement, Back Cover: adım 1, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement, Back Cover: adım 1, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement, Back Cover: adım 1, 3 resimden 3.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
    Das Honor 9 hat an der Unterkante keine Schrauben.
    Wie ist das Honor 9 zu öffnen?
    Michael Tuschek - Yanıt
    Vielleicht beantwortet diese Anleitung deine Frage ;)
    Tobias Isakeit -
    Hi, my P10 does not have screws, just two tiny holes. Do I push in here to unfasten? Einar, Norway
    Einar Ryvarden - Yanıt
    Hi Einar Ryvarden,
    in case you bought a used or refurbished phone, someone might have forgotten to put them back in. Since you have holes at the bottom edge next to the charging port this is likely. You can try to start with step 2 and see if you can lift the phone assembly (don’t forget to remove the SIM tray first). As far as I know there is no version of the regular Huawei P10 with no screws. However you there are none in the P10 lite and in the P10 plus, maybe one of the opening procedures for those phones might help you.
    Dominik Schnabelrauch -
  2. Huawei P10 Display Assembly with Frame Replacement: adım 2, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 2, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
    Hi! I cannot find a way to insert the plastic opening tool. Any suggestions on how I can create a gap to start. Everything seems quit rigid.
    Also, where will I find your reply.
    vbr/lars.skoldebring@gmail.com
    lars.skoldebring - Yanıt
    Hi Lars, you might want to use a suction handle to lift the display and create a small gap to insert the plastic tool. If you don’t have a suction handle you can “build” a handle with tape that you stick onto the display in a shape similar to this —> __∏__ (also you may want to edit your post and remove your email address ;) )
    Tobias Isakeit -
    Hi,
    I’m stuck at this step for about two hours… There’s nothing I can do to open the case. Tried all kinds of opening tools and a suction handle. There is no gap at all between the display and the body. How can anything be inserted into a gap that practically does not exist? Please help.
    Mark Movshovich - Yanıt
    Sorry to hear that. You could try and lift the display by using a suction cup and pull to create a small gap for a tool to get in.
    Tobias Isakeit -
  3. Huawei P10 Display Assembly with Frame Replacement: adım 3, 2 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 3, 2 resimden 2.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
    The cable is for the standby and volume buttons, not for the fingerprint sensor!
    JaL - Yanıt
    Thanks JaL, of course it is.
    Tobias Isakeit -
  4. Huawei P10 Display Assembly with Frame Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the two Phillips #00 screws.
    a me risultano PH000
    Il Lando - Yanıt
  5. Huawei P10 Display Assembly with Frame Replacement: adım 5, 2 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers to remove the two cable brackets.
  6. Huawei P10 Display Assembly with Frame Replacement: adım 6, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 6, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 6, 3 resimden 3.
    • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
  7. Huawei P10 Display Assembly with Frame Replacement: adım 7, 2 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 7, 2 resimden 2.
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
    • Use an iOpener to loosen the remaining adhesive.
    It wasn’t easy to find the piece to pull. It was a black label, folded and stuck to the battery
    Donato Grieco - Yanıt
  8. Huawei P10 Display Assembly with Frame Replacement: adım 8, 2 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 8, 2 resimden 2.
    Tesa 61395 Tape
    $5.99
    • Take care to not bend or puncture the battery.
    • Insert an opening pick or spudger beneath the battery and carefully pry it out.
    • Remove the battery.
    • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
  9. Huawei P10 Display Assembly with Frame Replacement, Display Assembly with Frame: adım 9, 2 resimden 1. Huawei P10 Display Assembly with Frame Replacement, Display Assembly with Frame: adım 9, 2 resimden 2.
    • Remove the four Phillips #00 screws.
    • Use tweezers to remove the metal plate that covers the charging board and the main flex cable.
  10. Huawei P10 Display Assembly with Frame Replacement: adım 10, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 10, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 10, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the flex cable of the headphone jack.
    • Remove the headphone jack with tweezers. There's a little adhesive underneath so it can be a bit sticky.
    • Unplug the antenna cable with tweezers.
  11. Huawei P10 Display Assembly with Frame Replacement: adım 11, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 11, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 11, 3 resimden 3.
    • Disconnect the main flex cable with a spudger and remove it.
    • Disconnect the loudspeaker flex cable.
    • Carefully remove the charging board.
  12. Huawei P10 Display Assembly with Frame Replacement: adım 12, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 12, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 12, 3 resimden 3.
    • Remove the vibration motor. If the adhesive is too strong, heat an iOpener to soften it and ease removal.
    • Use the flat end of a spudger to pry up under the speaker.
    • Remove the loudspeaker.
  13. Huawei P10 Display Assembly with Frame Replacement: adım 13, 1 resimden 1.
    • Remove the rubber gasket with tweezers.
    • If the gasket is included in your new part, there is no need to remove it from the old one.
  14. Huawei P10 Display Assembly with Frame Replacement: adım 14, 1 resimden 1.
    • Remove the four Phillips #00 screws from the motherboard.
  15. Huawei P10 Display Assembly with Frame Replacement: adım 15, 1 resimden 1.
    • Disconnect the antenna cable and remove it.
  16. Huawei P10 Display Assembly with Frame Replacement: adım 16, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 16, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 16, 3 resimden 3.
    • Use the pointed end of a spudger in the top right corner of the motherboard and pry it out until you can get a good grip.
    • The front and the rear cameras are still connected to the motherboard. Don't damage them while you remove the motherboard.
    • Remove the motherboard.
    • On the back of the motherboard there are thermal pads (pink rubber-like gobs) for heat dissipation. If these thermal pads broke or are too dried out you might need to apply new thermal pads on the new display assembly or the motherboard.
    Can I replace the pink thermal pad with thermal paste? Because I can't any online store sell pink thermal paste for phone.
    muhd syafiq - Yanıt
  17. Huawei P10 Display Assembly with Frame Replacement: adım 17, 3 resimden 1. Huawei P10 Display Assembly with Frame Replacement: adım 17, 3 resimden 2. Huawei P10 Display Assembly with Frame Replacement: adım 17, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • Remove the earpiece speaker with a tweezer.
    • Take care of the metal connectors to not bend them.
    • Carefully remove the proximity sensor from its recess.
    • Before reassembly check your new part for any components that might need to be transferred from the old one.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
Sonuç
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
25 farklı kişi bu kılavuzu tamamladı.
230.884 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.650 adet Kılavuz yazıldı
5Kılavuz Yorumları
Are the pink/purple blobs unter the motherboard thermal paste? If so, should I re-apply any when reassembling?
Martin Düren - Yanıt
The answer might come to late, as you most likely finished the repair in the last 5 years, but it might still be useful for others:
Yes, the purple blobs under the mainboard are thermal paste.
If the paste is still soft you could potentially reuse it but I would highly recommend to use some new thermal paste.
Nils Hennings -
Gonna upload an easy and faster way to do it whitout removibg the battery or upper boards and cameras, wait for it, my 1st guide.
mauro-diaz1 - Yanıt
I Need screen for p smart huawei2018
mbc judo - Yanıt
I didn’t add the tape. I don’t know why the battery comes with it, plus, it is ultra strong, I was all the time afraid to ruin the battery, but fortunatly, everything went well
Ciro Monteiro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 12
Son 30 gün: 96
Her zaman: 15,957
