Ana içeriğe geç
IdeaPad L340-15API Battery Replacement
Neye ihtiyacın var
  1. IdeaPad L340-15API Battery Replacement, Optical Drive: adım 1, 2 resimden 1. IdeaPad L340-15API Battery Replacement, Optical Drive: adım 1, 2 resimden 2.
    • Before beginning the repair, make sure that the device is fully powered off.
    • Turn the laptop over so the bottom cover is facing up.
    • The small screw hole near the center of the case, marked with a tiny DVD icon and an arrow, secures the optical drive.
    FixBot'a Sor
    Yorum Ekle
  2. IdeaPad L340-15API Battery Replacement: adım 2, 2 resimden 1. IdeaPad L340-15API Battery Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the 7.5 mm screw securing the optical drive.
    • Place the screw down safely in a container/magnet strip where it will not get lost while you are working. These screws are very small and easily misplaced.
    FixBot'a Sor
    Yorum Ekle
  3. IdeaPad L340-15API Battery Replacement: adım 3, 2 resimden 1. IdeaPad L340-15API Battery Replacement: adım 3, 2 resimden 2.
    • Place your thumb at the seam between the optical drive and the device.
    • Gently pull the component straight out from the device, taking care not to pull at an angle.
    FixBot'a Sor
    Yorum Ekle
  4. IdeaPad L340-15API Battery Replacement, Battery: adım 4, 2 resimden 1. IdeaPad L340-15API Battery Replacement, Battery: adım 4, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the twelve 7.5 mm screws from the back cover.
    FixBot'a Sor
    Yorum Ekle
  5. IdeaPad L340-15API Battery Replacement: adım 5, 3 resimden 1. IdeaPad L340-15API Battery Replacement: adım 5, 3 resimden 2. IdeaPad L340-15API Battery Replacement: adım 5, 3 resimden 3.
    • Insert a plastic opening pick in the back left corner and wedge the panel open.
    • Slide the pick around the edge of the laptop to release the clips as you lift the panel.
    • If the opening pick isn’t working, use the iFixit opening tool to gain more leverage.
    • Remove the bottom cover.
    FixBot'a Sor
    Yorum Ekle
  6. IdeaPad L340-15API Battery Replacement: adım 6, 2 resimden 1. IdeaPad L340-15API Battery Replacement: adım 6, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the five 6.5 mm screws securing the battery.
    • Use a container/magnet strip to store the screws while working.
    FixBot'a Sor
    Yorum Ekle
  7. IdeaPad L340-15API Battery Replacement: adım 7, 3 resimden 1. IdeaPad L340-15API Battery Replacement: adım 7, 3 resimden 2. IdeaPad L340-15API Battery Replacement: adım 7, 3 resimden 3.
    • Use the wide end of a spudger to push the connector tab, sliding the battery connector out of its socket.
    • It may take a lot of force to disconnect the cable. Go slowly, and don't pull on the cables.
    FixBot'a Sor
    Yorum Ekle
  8. IdeaPad L340-15API Battery Replacement: adım 8, 1 resimden 1.
    • Remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Ian
347 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Bowman Fall 2025 UMass Dartmouth, Team 2-5, Bowman Fall 2025 üyesi
UMASSD-BOWMAN-F25S2G5
4 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 55
Her zaman: 370
