Ana içeriğe geç
Insignia NS-CSPBTHOL-R Power Button Replacement
Judith Villegas
Judith Villegas ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
6 dakika
Kolay
Is the power button no longer powering on your device? This guide will help replace the power button so you can turn your speaker on and off.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Insignia NS-CSPBTHOL-R Power Button Replacement, Battery: adım 1, 1 resimden 1.
    • Push the Spudger into the crevice between the grated panel of the speaker and the base of the speaker.
    • Angle the spudger to create a separation between the grate and the base.
  2. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 2, 1 resimden 1.
    • Slide the spudger along the separation between the grate and the base of the speaker to loosen the grate. Do this to the entire perimeter of the speaker.
  3. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 3, 2 resimden 1. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 3, 2 resimden 2.
    • Pull the grated panel off.
  4. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 4, 2 resimden 1. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 4, 2 resimden 2.
    • Remove the six 3mm screws using the J00 JIS screw bit. This will require a long, narrow screwdriver.
  5. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 5, 2 resimden 1. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 5, 2 resimden 2.
    • Push the spudger into the crevice between the base and the face of the speaker and create a separation.
    • Slide the spudger along the entire perimeter and gently pull off the face of the speaker.
    • The two parts are connected by wires, do not rip them apart.
  6. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 6, 1 resimden 1.
    • Use the spudger to release the battery by sliding it underneath the battery to create a separation.
    • Remove the battery.
  7. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 7, 2 resimden 1. Insignia NS-CSPBTHOL-R Power Button Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Pull the motherboard from the base of the speaker.
    • Using tweezers, squeeze and pull on the white plastic clip that connects the battery wires to the motherboard.
    • Unclip the battery from the motherboard.
  8. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: adım 8, 3 resimden 1. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: adım 8, 3 resimden 2. Insignia NS-CSPBTHOL-R Power Button Replacement, Power Button: adım 8, 3 resimden 3.
    • Using tweezers, detach the power button from the mother board.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Judith Villegas
312 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 12-6, Eyestone Spring 2017 USF Tampa, Team 12-6, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S12G6
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 635
