Ana içeriğe geç
JBL Charge 4 Charging Port Bay Replacement
Neye ihtiyacın var
  1. JBL Charge 4 Charging Port Bay Replacement, Speaker Grill: adım 1, 1 resimden 1.
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
    ich schaffe es nur auf der einen seite. Auf der anderen ist die abdeckung viel zu fest dran ? was kann ich machen ?
    George Ziakos - Yanıt
  2. JBL Charge 4 Charging Port Bay Replacement: adım 2, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 2, 2 resimden 2.
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    You have to remove the 8 mm screws before you try and Prius the other side. They are attached, and will break
    Noah Werthaiser - Yanıt
  3. JBL Charge 4 Charging Port Bay Replacement: adım 3, 1 resimden 1.
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: adım 4, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement, Passive Bass Radiators: adım 4, 2 resimden 2.
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
    There is absolutely no reason to remove the passive radiators if you want to replace the speaker only!
    Just cut to step 6.
    Also the difficulty level is way too high. I found it very easy to disassemble the unit.
    Paul Decaro - Yanıt
  5. JBL Charge 4 Charging Port Bay Replacement: adım 5, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 5, 2 resimden 2.
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
  6. JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: adım 6, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement, Charging Port Bay: adım 6, 2 resimden 2.
    • Remove the two 6mm Phillips #0 screws from either side to remove the port bay cover.
  7. JBL Charge 4 Charging Port Bay Replacement: adım 7, 1 resimden 1.
    • There are two hooks that attach the opposite side of the port bay cover to the device. Slide the cover back and off the hooks.
    • Remove the port bay cover.
  8. JBL Charge 4 Charging Port Bay Replacement: adım 8, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 8, 2 resimden 2.
    • Remove the six 6mm Phillips #0 screws.
  9. JBL Charge 4 Charging Port Bay Replacement: adım 9, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 9, 2 resimden 2.
    • Before removing port bay you must detach the connecting tabs on either side of the device.
    • Press on the tab and gently pull out the wire connector.
  10. JBL Charge 4 Charging Port Bay Replacement: adım 10, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 10, 2 resimden 2.
    • Remove the second connector on the opposite side by gently pulling it out.
  11. JBL Charge 4 Charging Port Bay Replacement: adım 11, 1 resimden 1.
    • Remove the port bay from the device and place the device to the side.
  12. JBL Charge 4 Charging Port Bay Replacement: adım 12, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 12, 2 resimden 2.
    • Remove the three 9mm Phillips #0 screws from the board.
  13. JBL Charge 4 Charging Port Bay Replacement: adım 13, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 13, 2 resimden 2.
    • Using the plastic opening tool, lift the board from the port bay holder.
  14. JBL Charge 4 Charging Port Bay Replacement: adım 14, 2 resimden 1. JBL Charge 4 Charging Port Bay Replacement: adım 14, 2 resimden 2.
    • Choose which port you want to replace.
    • Turn the board around and desolder the connection to remove the chosen port.
    • A guide for soldering and desoldering can be found here.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Zachary Colwell
2.031 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S1G1
4 Üyeler
27 adet Kılavuz yazıldı
10Kılavuz Yorumları
Does anybody know which exact ports I have to get? There are a ton of different models out there.
Ulpi - Yanıt
You can purchase charging sockets from ebay by searching for "jbl charge 4 usb-c port" (without the quotation marks) or if you don't feel like replacing the charging port yourself, there are mail-in repair services available also.
Simon -
Ijust change the battery on my jbl charge4 it is not powering on or even charging what going on?
pipask1 - Yanıt
Ersatzteil:
✅ JBL Charge 4 Bluetooth Lautsprecher Micro USB C Buchse Ladebuchse Connector
https://www.ebay.de/itm/164897748374
Falls Sie beim Austausch der Buchse Hilfe benötigen:
✅ REPARATUR Austausch Micro USB C Buchse Ladebuchse Anschluss Port JBL Charge 4
https://www.ebay.de/itm/164975006896
PC-Solutions - Yanıt
I could not change the USB-C myself so had it soldered in a shop for me. For the rest of the procedure, I could perform it alone thanks to this guide, now the device works again. Thanks!
sylkys - Yanıt
i want to charge the battery straight not through charging port, which wires can i connect with th charger
Shamena Ephraim - Yanıt
A thoroughly and well performed guide, thumbs up!
Jesper Widell - Yanıt
Where to get the ports… eBay link doenst work
Maarten Keus - Yanıt
You can buy ports from ebay by searching for "jbl charge 4 usb-c port" (without the quotation marks) or if you don't feel like replacing the charging socket yourself, there are mail-in repair services available also.
Simon -
charging port damage
Jbl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 320
Her zaman: 25,921
