Ana içeriğe geç
Jadoo 3 Power Port Replacement
The Mariocrafter
The Mariocrafter ve 2 diğer katkıda bulunanlar
En son July 30, 2024 tarihinde güncellendi
Tahmin yok
Orta
Gramer Polisi
Daha İyi Resimler Gerekli
Topluluk-Katkılı Kılavuz
Original from https://www.electronicslovers.com/2015/0...
Hello Electronic Lovers, in this tutorial I will show you how to repair a broken Power port of the JADOO box. You can Replace a Power Port or by connecting charger wires directly to the main circuit. We need 5v DC output from the charger or power supply to run JADOO box. I will recommend to change a Port instead of connecting wires directly.
Neye ihtiyacın var
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Jadoo 3 Power Port Replacement, Power Port: adım 1, 1 resimden 1.
    • The box back cover doesn’t not has screw, just use any sharp thing, knife, in the edge of the box and pull the sharp thing , knife, a cover will be popped up and take out The circuit Board carefully.
  2. Jadoo 3 Power Port Replacement: adım 2, 3 resimden 1. Jadoo 3 Power Port Replacement: adım 2, 3 resimden 2. Jadoo 3 Power Port Replacement: adım 2, 3 resimden 3.
    • Cut the power cable and peel the wire and 2 wire should be appear black and red as shown in picture
  3. Jadoo 3 Power Port Replacement: adım 3, 1 resimden 1.
    • Black wire will be connected to the first point on the right side and Red wire will be the first point on left side of the board. If in case doesn’t work the change the step to the opposite.If board lights on its mean wire should be solder with the board.
  4. Jadoo 3 Power Port Replacement: adım 4, 2 resimden 1. Jadoo 3 Power Port Replacement: adım 4, 2 resimden 2.
    • For the safety of wire melt the glue stick on wire with board to safe from moving
Sonuç
The Mariocrafter
1.533 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 87
