Ana içeriğe geç
LG Chocolate 3 Display Connector Replacement
Neye ihtiyacın var
  1. LG Chocolate 3 Display Connector Replacement, Display Connector: adım 1, 1 resimden 1.
    • Remove the battery and expose the motherboard following the General Disassembly LG VX8560. You will have to replace the side keys once finished with this guide.
    • Locate intertwined blue and red wire (screen display connector.)
  2. LG Chocolate 3 Display Connector Replacement: adım 2, 1 resimden 1.
    • (Ignore this step if the screen display connector is already separated from the motherboard) Using the spudger, place the pointy end between the plastic end of the wire and the motherboard and lift/push wire from the motherboard socket. You should see two golden pins protruding from the plastic.
    • Align the two golden pins at the end of the wire with its respective socket on the motherboard and gently push down until you hear a click-sound.
    • To reassemble your device, follow Side Keys Installation in reverse order.
Bitiş Çizgisi
Mitchel
1 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G62
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 340
