Ana içeriğe geç
LG Front Load Washing Machine Main Board Replacement
Neye ihtiyacın var
  1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement, Safety Precautions: adım 1, 2 resimden 2.
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    FixBot'a Sor
    Yorum Ekle
  2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    FixBot'a Sor
    Yorum Ekle
  3. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: adım 3, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement, Remove the top panel: adım 3, 2 resimden 2.
    • Slide the top panel towards the rear of the device to disconnect its clips.
    FixBot'a Sor
    Yorum Ekle
  4. LG Front Load Washing Machine Main Board Replacement: adım 4, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement: adım 4, 2 resimden 2.
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    FixBot'a Sor
    Yorum Ekle
  5. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: adım 5, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement, Disconnect the pressure sensor: adım 5, 2 resimden 2.
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
    FixBot'a Sor
    Yorum Ekle
  6. LG Front Load Washing Machine Main Board Replacement: adım 6, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement: adım 6, 2 resimden 2.
    • Disconnect the hose from the pressure sensor.
    FixBot'a Sor
    Yorum Ekle
  7. LG Front Load Washing Machine Main Board Replacement, Unfasten the pressure sensor: adım 7, 1 resimden 1.
    • Remove the screw(s) securing the pressure sensor.
    FixBot'a Sor
    Yorum Ekle
  8. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: adım 8, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: adım 8, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Remove the pressure sensor: adım 8, 3 resimden 3.
    • Unclip the pressure sensor from the chassis or other components.
    FixBot'a Sor
    Yorum Ekle
  9. LG Front Load Washing Machine Main Board Replacement: adım 9, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement: adım 9, 2 resimden 2.
    • Lift the pressure sensor away chassis and remove it.
    FixBot'a Sor
    Yorum Ekle
  10. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: adım 10, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: adım 10, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Disconnect the control panel cover: adım 10, 3 resimden 3.
    • Disconnect any cables or fasteners secured to the control panel cover.
    • Repeat this procedure for any bundled cables that keep the cover from opening.
    FixBot'a Sor
    Yorum Ekle
  11. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: adım 11, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: adım 11, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Remove the main board cover: adım 11, 3 resimden 3.
    • Use a flathead screwdriver or a prying tool, to unclip the main board cover.
    • Remove the main board cover.
    FixBot'a Sor
    Yorum Ekle
  12. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: adım 12, 2 resimden 1. LG Front Load Washing Machine Main Board Replacement, Unfasten the main board: adım 12, 2 resimden 2.
    • Remove the screw(s) securing the main board to the back side of the washer.
    FixBot'a Sor
    Yorum Ekle
  13. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: adım 13, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: adım 13, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Separate the main board from the chassis: adım 13, 3 resimden 3.
    • Slide the main board out of its slot in the chassis.
    FixBot'a Sor
    Yorum Ekle
  14. LG Front Load Washing Machine Main Board Replacement, Remove the main board: adım 14, 3 resimden 1. LG Front Load Washing Machine Main Board Replacement, Remove the main board: adım 14, 3 resimden 2. LG Front Load Washing Machine Main Board Replacement, Remove the main board: adım 14, 3 resimden 3.
    • Label each connector and its spot on the main board. During reassembly, reattach each connector to its proper spot.
    • Lift the main board out of the chassis to access each of the connectors.
    • Disconnect each connector from the main board.
    • Remove the main board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Ask our Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Bill Gilbert
39.917 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.572 adet Kılavuz yazıldı
1Rehber Yorum
Thank you for the instructions. Can power to the front control panel be tested without connecting the pressure sensor and water lines.
albert - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 24
Son 30 gün: 97
Her zaman: 4,151
